Author Subject: reving up on tickover
domtwpgti
occasionally my gti6 will rev up and down on its own when on stop. does anyone know what it is?
Posted 27th Oct 2009 at 23:18
sixysix
I had a similar thing happen a while back along with stalling issues.
Turned out to be a split in the small pipe that comes off the inlet pipe which connects to the stepper motor.
I replaced the hose (
Take a look
Posted 28th Oct 2009 at 01:07
domtwpgti
thanks. i will have a look tomorrow.
Posted 28th Oct 2009 at 01:17
crawfy
This is happens to my 6 aswel, seems to be worse when hot, will have to have a look in work tomorrow when its daylight!
Posted 28th Oct 2009 at 02:00
gti6girl
air leak Smile
Posted 28th Oct 2009 at 02:53
domtwpgti
had a look at mine today. there was a crack in the pipe leading to the steper motor/idle control valve which i have bonded up for the time being. and also my steper was all cacked up so cleaned with a bit of plus gas and a rag. when i get it finished i will post the results. cheers.
Posted 29th Oct 2009 at 01:36
domtwpgti
finished off the car today and it runs better than ever. bearing in mind i have just replaced all the valves due to a timing belt tensioner giving up. can recomend doing the above. cowabunga man!
Posted 2nd Nov 2009 at 03:56
gti-si
I think cleaning the stepper motor is the job. The crack in the pipe won't make a difference as it's still unmetered there and the flow is controlled by the motor, any air leaks AFTER the tb/stepper would caue a problem
1990 Cherry Red 205 Gti-6
2000 Mitsubishi Galant V6
Posted 2nd Nov 2009 at 05:12
allesclar
glad you got it sorted Smile
Team allesclar ®
Posted 2nd Nov 2009 at 05:21
