Author Subject: Engine Management light
anth
Came on today when going down the motorway at about 80ish noticed it was on then.
Was on for about 5 mins then went out when i came to about 20mph or less (coming to a stand still)
Didnt come on again but i didnt go much above 40 mph.
The only other things thats are currently wrong is sometimes it gets a bit lumpy when it gets hotter think this is the lambda/cts.
But it happens rarely.
Do yout think i should be worried or is the engine management light a sign of the lamda dying?
The fuel cosumption is spot on up to 380-400 miles a tank if driven resonably.
Pull off is a bit slugish but this i guess is because of heatsoak with the induction kit that i also need to replace when i can
Thanks
Posted 27th Oct 2009 at 00:23
anth
anyone hazard a guess?
The light hasn't come on since.
Although it bogged down massively when i pulled off earlier tonight.
Starting to think spark plugs can they cause the management light to come on?
Posted 28th Oct 2009 at 00:00
every time i have had engine management, every single time without fail, it has been the lambda
it is doing it now infact - it will come on and disappear if i rev it and alternate the rpm
Posted 28th Oct 2009 at 00:08
if you unplug a coil the engine management light comes does it not ???? could be a failing coil pack ?????
Posted 28th Oct 2009 at 00:13
anth
hmmm would make sense as that and the cts could be causing the lumpiness when its hot.
Posted 28th Oct 2009 at 00:25
anth
Im hoping that may have been the plugs instead of the coils, will have to try new plugs first. Going to be a mission if its a coil to find which one is causing that.
will try the lambda too.
Thanks guys
Posted 28th Oct 2009 at 00:31
tvrfan007
If you come by Peterborough I have the ELM and scanning software, could read any codes stored for free. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 28th Oct 2009 at 00:30
anth
Thanks mate quite a way to drive tho LOL
Posted 28th Oct 2009 at 00:51
webster
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 3rd Nov 2010 at 15:24
