Author Subject: 406 V6 into 306 wiring
kezman7
I have been looking round and can get the complete engine with clutch, shaft ect everything for
Posted 26th Oct 2009 at 03:58
easy enough, done one into a 205, process would be the same.
Posted 26th Oct 2009 at 04:06
kezman7
Is it as much plug and play or is it more slicing and diagrams to work it out from?
Posted 26th Oct 2009 at 04:23
Depends on the donor car and its wiring type. D8 is fine, D9 much harder.
Posted 26th Oct 2009 at 04:37
kezman7
Ok have emailed them see if i can find out
Posted 26th Oct 2009 at 04:51
nothing is ever plug and play!
D9 with VVT 210ps engine will need Aftermarket management.
Posted 26th Oct 2009 at 14:23
kezman7
Its a D8 so thats a good thing to hear, I knew it wouldnt be stright plug in i ment it as easier then as said needing a new management.
Posted 26th Oct 2009 at 15:51
marksorrento205
If I have managed to wire one into a 205 it cant be that hard LOL Joking apart as WP said its easy enough once you have the wiring diagram you figure out what wire is what.
Posted 26th Oct 2009 at 17:32
kezman7
Is there any diagram currently about? Also how would thje hydralic clutch ect work into a 306.
Posted 26th Oct 2009 at 18:20
kezman7
Right i have had 2 peices so far and it looks like atm it wont be worth getting the current engine fixed for the cost, So im wanting to know before i make final decision pretty much exactly is involved in fitting the V6,
From what i gathered the driveshafts need shortening, and bottom mount needs moving across, How would the hydralic clutch work and also the ECU side of things?
Are the V6 shafts fit into the 306 hubs ect and anyone got a wiring diagram i can look at just to ge ta general idea.
Thanks
Posted 28th Oct 2009 at 04:06
