Author Subject: Calliper dust seal
gman
After being sold a set of dodgy callipers (A K Knight), I can't seem to be able to remove the spit dust seal.
I've removed the piston, but the seal seems to be tucked inside a sort of liner. Is this normal or should the seal come out with the piston.
How can I get it out???
Thanks
Graham
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 25th Oct 2009 at 02:54
fripper
Any pics?
Love my 306 GTI
Posted 25th Oct 2009 at 18:00
stilly
try using a very thin flat head screw driver or a pin...Big grin
deaf in 1 eye blind in 1 ear Crazy......
307 136bhp daily drive.....
306 rallye stripped out and charged.....
lee_gti6 also known as "the tit".....
stan_306gti6 also known as "stan the dick".......
Posted 25th Oct 2009 at 18:18
tvrfan007
Lets see the pics. Presume you're talking fronts? Usually they just tuck into a lip in the bore.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 30th Oct 2009 at 00:14
If they are Brembos, you will have to carefully dig all of the rubber out from around the edge of the seal with a small pick or sharp screwdriver, just removed all 8 dust seals on Chris with a pug's new Brembos, takes a bit of patience but there is a steel rim moulded into the seal and it's quite a tight fit so you need to get out as much rubber as you can to make it easier to prise out the remainder of the seal, no way to fget them out without destrouyng that type I'm afraid.
Posted 30th Oct 2009 at 00:25
gman
Cheers for the advice lads. I just wasn't pulling on them hard enough as I didn't want to tear them but they're off now.
Thanks again
2002 Audi S3 (Sold)
Posted 30th Oct 2009 at 00:30
