Author Subject: ticking/ tapping
simont642
i have recently had my head redone ive had fast road piper cams gas flow acid wash ported and polished 2 new valves all valves reground and seated all new gaskets and seals. i had all the tappets and lifters checked and was told they was all ok. but the car still sounds like it has tappititus could anybody help on if it could be anything else?? thanks
Posted 24th Oct 2009 at 21:55
allesclar
if you have had it done by professional, take it back and get them to verify its not a tapper or get it redone properly.
Team allesclar ®
Posted 24th Oct 2009 at 21:58
simont642
i have thought about it but they are not willing to take the head back apart because they dont like to store the cars. i have read it could be the injectors. but it definetly sounds like tappets!!
Posted 24th Oct 2009 at 22:04
gti6girl
dependant on sound it could be :
exhaust manifold leak
injectors
loose spark plugs
tappets
or still f*cked
Posted 24th Oct 2009 at 22:07
allesclar
if they did work on it, if its not working still, take it back. cheeky f*ckers, cant be bothered to look at it as they dont have the storage.
Team allesclar ®
Posted 24th Oct 2009 at 22:09
simont642
i will try that then. the sound was there before i had the head done so was hoping the work would cure it. thanks
Posted 24th Oct 2009 at 22:14
fergusxsi
might it be worn shims on top of the tappets where the cam meets it?
Posted 25th Oct 2009 at 05:07
simont642
im not sure. im never saw that part of the head as it was assembled at the garage and to be quite fair i wouldnt know what they look like anyway. i just trusted the garage on what they said.
Posted 25th Oct 2009 at 13:11
these dont have shims as far as i am aware
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 25th Oct 2009 at 13:20
peugeot dave
if it is the head tapping i would take it back and give them 2 options either fix it or give you your money back.
dont fall into a trap getting spun off by bullshit even trading standards will be with you on this one (if its the head of course) good luck hope all is sorted soon.
my car's spending all my money grrrrrrrrrr
Posted 25th Oct 2009 at 13:46
chris with a pug
If its a tapper it will sound like a sowing machine.
And no these engines dont have shimes the tappets are hydrailc
Posted 25th Oct 2009 at 14:32
simont642
you can hear it through the rev range. it definetly sounds like its coming from the top of the engine!!
Posted 25th Oct 2009 at 19:12
simont642
i have been to see the guy that did the work and he says to bring it in on monday for repair. he says its something on the inlet side of the head!!
Posted 7th Nov 2009 at 00:51
simont642
i have taken the car and the problem is somebody has rebuilt the bottom end and has put the number 1 piston in number 4 2 into 3, 3 into 2 and 4 into 1 so the pistons are hitting the valves hence the tapping noise so it looks like an engine out jobby!!!
Posted 12th Nov 2009 at 02:47
which cylionder the piston was in originally and which it is in now would not affect this, I think someone has skimmed too much off the head.
Posted 12th Nov 2009 at 03:08
simont642
i range peugeot and they confirmed that you can get then mixed up!and the piston has a shiney spot on it where it has been tappin the piston but i will investigate further before i make any decisions!!
Posted 13th Nov 2009 at 03:53
