Author Subject: Beam mounts?
big_jim
Whats the best to use and where to get them from.
I'm thinking of selling the car, but incase it doesn't sell, i want to improve what i can...
How much difference will they give?
Hard job?
Posted 23rd Oct 2009 at 03:34
Are you after solid or normal ones?
Posted 23rd Oct 2009 at 03:41
big_jim
Whatevers best, better handling?
Posted 23rd Oct 2009 at 03:47
Best to do a search, I make solid rear beam mounts and I really like the difference they make to the handling, but a certain member on here has given he a hard time for my opinions on rear end sway induced by the passive rear steer from rubber mounted rear beams. IMO the standard setup is a perfectly good system when in good condition and driven under normal limits, but it's a flawed design with respect to high speed/track driving as the gometry is affected by bumps and braking. This passive rear steer can be very helpful under certain circumstances, but by the same token it can also be very unhelpful. Solid mounts remove all traces of rear steer and allow the suspension to move in one plane only (Up and down) I have found this increases stability especially on fast sweeping curves especially if they are bumpy.
Posted 23rd Oct 2009 at 03:58
big_jim
What sort of price do you charge?
Hard to fit?
Posted 23rd Oct 2009 at 04:06
Posted 23rd Oct 2009 at 04:20
cwspellowe
How long have you had your car? Might be worth looking at GSF for them, i got my standard replacement jobs for
Bye bye Sundance Kid Sad
Posted 23rd Oct 2009 at 04:30
big_jim
Might try that first..
Posted 23rd Oct 2009 at 05:04
Just in case you change your mind? Whistle
Posted 24th Oct 2009 at 03:47
