Author Subject: 205 Box on a 306
cbgbrally
Does anyone have any experience of bolting a 5 sp BE3 box from a 205 staight in to a 306 rallye?
Is it a straight swap, or are there any things i need to know?
Posted 22nd Oct 2009 at 18:17
gman
use a Xsara VTS box instead if you're after 5 speeds. Otherwise it's not a straight swap, I think you need to use an 405 mi16 clutch.
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 22nd Oct 2009 at 18:37
cbgbrally
Is this due to the casing or the internals ?
Posted 22nd Oct 2009 at 18:44
the 205 1.9 box is meant to be a good 'un ..
Posted 22nd Oct 2009 at 19:19
I was under the impression that you would just have to change the selector fork over and possibly move the mount. Don't see why the clutch would have to be changed. I used a 405 Mi16 box in my 205 and its the same box as the Xsara VTS.
Posted 22nd Oct 2009 at 19:24
jonnie205
The bellhousing is different, the xsara vts and gti6 has a stronger belhouising with extra bolts holding sump to bellhousing
Posted 22nd Oct 2009 at 19:39
marksorrento205
A 205 box uses a push clutch not a pull clutch hence why people fit an mi16 clutch as it bolts straight on to the 6 flywheel, is bigger than a 205 one and is a push type. It may be possible to swap the clutch fork assy and retain the pull clutch?
Thumbs up to a xsara vts box but why would you want to fit a 5 speed to the rallye?
Posted 23rd Oct 2009 at 00:19
cbgbrally
quote:
[quote="markrallye
Because i currently have a 5sp be3 with a quaife 4.8 and tranx on my 205 , I'm looking at various options for next years road rallying . A 306 rallye or another 205 with a GTi 6 engine
Posted 23rd Oct 2009 at 00:33
marksorrento205
Sweet and you want to keep the box. I dont blame you Smile Are any of them bits able to be put into the 6 speed box? Miles is your best bet to ask!!
Posted 23rd Oct 2009 at 01:20
swap the clutch arms and cable brackets off your gti6 box to the 205 box, use the gti6 clutch Smile
should be damn good fun with the 4.8 FD, which gearset does it have?
Posted 23rd Oct 2009 at 02:19
cbgbrally
Thanks for that , it the std 1.9 gearset , so is good for about 117 flat out .
Are the 1.9 5 sp gears considered stronger that the 6 speed ones?
Posted 23rd Oct 2009 at 13:04
monty-69
Think the speedo drive assembly will need swapping over as well if you want an accurate speedo.Both the plastic cog that pulls out of top of diff and the plastic drive pinion in the diff. Thumbs up
Posted 24th Oct 2009 at 16:31
