Author Subject: Clutch Problem
chewitt
My XSi 2.0 16V Phase 2 has a really heavy clutch.
Well I think that's what you call it.
It's really stiff and hard to push down.
It is driveable and I have managed with it for the last few months but it is time to do something about it.
As I can't feel the "bite", it's hard to judge the gear change at low gears, meaning gear changing is slower and not as smooth. Heavy clutch also tires out my leg!
What could be causing this? Cable?
Also, when pulling off in first gear, as I'm at the bite and giving it gas, the car rumbles a lot. It's like some sort of clutch plate rubbing or something.
I don't know the tech words for the clutch so any help would be gratefully appreciated.
306 LX 1.4 Phase 2
**Current Body Mods**
4 x 4" Exhaust System
Full B/Kit (Front, Skirts, Mirrors & Rear)
Bonnet with Scoop
Full Tinted Rear Windows
17" Alloys
Lights
Posted 22nd Oct 2009 at 14:33
I think you need to:
a. search - its been covered many times
b. put it in the right section
c. change the cable to see what difference it makes
d. describe the 'rumbling' sound a bit better
e. be prepared to change the clutch as the bearing could be on its way out
HTHThumbs up
Posted 22nd Oct 2009 at 14:51
al4x
cable won't make a long term difference if its heavy either put up with it or change the clutch.
Posted 22nd Oct 2009 at 15:09
True, changed mine. It got better for 2 days and then the bearing destroyed itself Roll eyes
Posted 22nd Oct 2009 at 15:13
chewitt
Thanks for the replies.
a. I wasn
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 22nd Oct 2009 at 15:14
jimmah
Transmission section
1998 (S) Phase 2 Diablo Red GTI-6
Posted 22nd Oct 2009 at 15:29
jimmah
Transmission section is your best bet!
Posted 22nd Oct 2009 at 15:26
chewitt
Ah, I didn't see that.
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 22nd Oct 2009 at 15:41
Fair enough.
Its not that hard, but not that easy either (easier for you though with a 5 speeder). If you are worried about doing the cable then taking the gearbox off is a few steps further up. Best to have a friend with you to do the cable - the FAQ is good.
Some forum guys might be able to help you out - Stilly or Miles are probably closest. Might be worth asking Welshpug as he is down that way quite a bit. Clutches are around the
Posted 22nd Oct 2009 at 19:18
