Author Subject: 406 brembo disc options?
MCH_GTi6
formerly mch
I've seen various threads regarding what discs can be used to fit the 406 brembo's when fitting to a gti6
206 GTi 180's
Xantia V6
307 110Hdi
Which are the best to use?
As it appears the xantia discs sit slightly off center which could be one of the causes of the squeel?
are the 206 or 307 ones better?
Team Moonstone� Ph3 GTI6
Team Rallye
Posted 21st Oct 2009 at 20:21
rob dog
I'd like to know the answer as well as i've just started on this today. Anybody got 15" rims over the 406 brembo ?
Posted 21st Oct 2009 at 22:56
pugheaven
2 types of xantia disc's 283mm and 288mm i think and the larger one of the two sit in the centre of the caliper and not offset like the other ones.
I used these discs, they do squeel tho.
Think they fit behind some aftermarket 15" alloys
Posted 21st Oct 2009 at 23:03
rob dog
i use the 1.9 205 gti alloys (as its a rally car) can i use these wheels with spacers to fit over the caliper ?
Posted 21st Oct 2009 at 23:08
lotek
No with spacers maybie but they would be big spacers
Posted 21st Oct 2009 at 23:20
pugheaven
i had 15" wolfrace voodoos and they fit with no spacer, cant remember what et they were tho
Posted 22nd Oct 2009 at 00:26
MCH_GTi6
formerly mch
So which discs sit dead center in the caliper?
Team Rallye
Posted 22nd Oct 2009 at 00:34
lotek
you would need ash's or carls bell and rota set up apparently
Posted 22nd Oct 2009 at 00:47
pugheaven
i swear my 288mm x 28mm discs sat central.
Posted 22nd Oct 2009 at 01:10
bellcp306td
http://www.306gti6.com/forum/showthread.php?id=113331&page=1
try this hope it helps.
i ran 307 110HDi with the Brembo's
Where did the road go!
Posted 27th Oct 2009 at 18:02
russbez
arent the 307 hdi ones and 206 gti180 the same discs?
My Rallye project thread
Posted 27th Oct 2009 at 18:28
So do mine Yes
Posted 27th Oct 2009 at 18:34
bellcp306td
The 307HDi and the 206GTi are the same disc i think. Dont use the 406 Brembo's unless you use bells and adapters to make a 330 disc setup. I have moved to Renault Brembos form a 195 using a 406 305mm disc.
Posted 27th Oct 2009 at 18:38
rob dog
Did a trial fit today with xantia disc's, will require a few small tweeks and a 12mm spacer but will be able to run 1.9gti alloys. happy days.
Posted 27th Oct 2009 at 21:05
