Author Subject: vts gearbox help
bobdylan_55
hi guys, im currently looking at new gearbox alternatives as i do not think my 309 1.9 gti gearbox will be strong enough.
my question is, i have purchased a vts gearbox from the xsara, now would there be any point in fitting a quaife diff to this, or would i be better just fitting the quaife diff to the 1.9 box? im just thinking apart from the diff are the strength of the actual gears any different?
if ive confused you, basically i need to know
are the gears stronger in the vts box (not the diff etc, just the gears)
cheers
309 GTi6-T
Posted 21st Oct 2009 at 15:30
bobdylan_55
also any ratios of vts gearbox would be grateful Smile
309 GTi6-T
ask Miles Thumbs up I think the casing is good, but there are weaknesses inside compared to the older boxes, but may be wrong LOL
ratios are the same as Mi16 and S16.
quaife would be a good idea, if its going on your turbo project you may find using the 1.9 Final drive with the Xsara gearset would work well as they'd be a litle bit longer.
Posted 21st Oct 2009 at 15:39
miles
The Xsara box's are weaker internally to the diff due to the cut of the Gear's much like the GTi6 box.
Depending on the age of the box you will find that the later Pinion shaft is different in length and spline length & Dia.
www.pugracing.com
Posted 22nd Oct 2009 at 03:19
bobdylan_55
ok so i have a 1.9 gti box (be1 old style) and a vts box, which would you go for? it will be connected upto a gti6 turbo engine fitted into a 309 cheers
309 GTi6-T
Posted 23rd Oct 2009 at 03:19
bobdylan_55
any how come they didnt just keep using the 1.9 boxes on the newer cars?
309 GTi6-T
Posted 23rd Oct 2009 at 03:26
because they didnt use the 1.9 engine.
Posted 23rd Oct 2009 at 03:40
bobdylan_55
but dont they fit all the xu blocks? i thought they were all pretty much interchangeable with the exception of release forks and arms which arnt exactly hard to change, so surely if the gears were stronger theyd use the old 1.9 boxes?
i know the gear cut are different but did the newer boxes have heat treatment of any kind as this increases the strength of the boxes quite a bit. or is it just the diff thats weaker?
309 GTi6-T
Posted 23rd Oct 2009 at 03:43
cbgbrally
I think we are asking a similar question , that welshpug has answered in my thread . Cheers
Posted 23rd Oct 2009 at 13:05
Might be worth having a look into ML boxes instead then - there is some info on here about them. Depends on the torque you are hoping to put through it.
Posted 23rd Oct 2009 at 17:46
