Author Subject: More BHP?
big_jim
What can be done to the gti to up the power without spending fortunes?
Im thinking around 200bhp?
It already has a k&n and full decat exhaust.
Cams?
Manifolds?
Whats been done and works?
Also, has anybody turbo'd one?
Posted 18th Oct 2009 at 16:56
Been covered on here hundreds of times mate so you won't get much of a response. Your best bet for more power under a grand is cams (Mild ones lik PT81s because valve to piston clearance is marginal on standard pistons) an induction kit (A proper one with a decent cold air feed) and a good exhaust (Magnex if you don't mind the noise) and maybe a decat if you don't mind a trip under the car to change it for MOTs once a year. But all that will only get you to maybe 185-190 without headwork / remap. For more you will be spending
Posted 18th Oct 2009 at 17:15
misschief
If you want to make it go faster, it's far cheaper to lower the weight than boost the power! makes it a bit of a nightmare for commuting though!
Posted 18th Oct 2009 at 17:17
big_jim
Its got a magnex on it with a decat..
Its a second (3rd if you include the van) car.
I think i'd take it on a track when i can.
Im used to RWD so its a bit different for me, and its slower then my old car. Just thought it'd make a good track car as ive had one before and was impressed with it.
Dont want to strip it out as ive got a 1 year old, she doesn't go in it, just would like to be able to if i needed to.
Feels like im doind 120 at 80!! The rear Shocks are dead! Took it for a test drive at normal speeds, seemed ok.
Took it out for a blast on some country lanes, lifted at speed and the back end tried to take off!!!
Posted 18th Oct 2009 at 17:28
Most will do that mate Yes LOOS!
Get it lowered, suspension refresh and maybe some solid rear beam mounts, before you add more power.
Posted 18th Oct 2009 at 19:07
big_jim
Yeah but this was BAD!
Think ive got some bits sorted now.
We'll see...
Posted 18th Oct 2009 at 19:30
