mark stewart
| Author | Subject: 306 gti and xsara vts, |
5097mark
Newbie Location: crook Registered: 06 Jul 2008 Posts: 6 Status: Offline |
Is there any differance in the engines that i should know about because im putting my old xsara engine in my 306 gti next weekend! I own a xsara vts with a knackered rear beam and a 306 gti 6 with a knackered engine so im going to make the mighty gti live on! any help would be great cheers lads________________________________________ mark stewart |
monkgti
Regular Location: New Ross Registered: 31 Jul 2009 Posts: 343 Status: Offline |
there the same lad, only difference is the box but you'll be keeping your 6 speed in the 306 yes???________________________________________ IF YOU CAN READ THIS IM STILL IN 5TH!!! |
aaron6
Aint there something different with the ecu and cats?________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
aaron6 wrote: Aint there something different with the ecu and cats? Only on later VTSs after ~2002 when a second lambda was fitted after the cat for emissions. ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
[l\'e$kro]
Newbie Location: cork City Registered: 16 Feb 2009 Posts: 40 Status: Offline |
according to this topic: http://www.306gti6.com/forum/showthread.php?id=104582&page=7You have a few more differences between ph2 Xsaras and gti-6 Basically the whole management s different ECU, Loom and sensors, and for the mechanical part, I guess the Fuel pressure regulator is also different? Nicolas ________________________________________ 205 gti xu10j4rsms2 extra sequential |
