Author Subject: Clonk after lowering
hainesygti6
I have a phase 1 306 which i recently lowered 35mm on the front, After lowering a clonk from the offside front developed when i'm turning at a junction or doing somesort of very slow turn. It was always abit juddery from the offside front before but it seems tohave got alot worse after lowering it. The only thing i can think is the driveshaft as the angle has changed?
Refurbing Cyclones Black work in progress!
Phase 2 rear light conversion to go on.
Posted 15th Oct 2009 at 00:54
Could be, more likely its the balljoint is loose in the hub.
Posted 15th Oct 2009 at 01:00
hainesygti6
I forgot to add that there is cv grease all over the strut and arch liner but not sure weather this is from old as i have only owned the car a few weeks, think ill change it anyway.
Posted 15th Oct 2009 at 01:03
puglover Banned!
split cv boot on driveshaft?
dry cv joint making noise.
new driveshaft
Posted 15th Oct 2009 at 01:10
david xsi
I had the same problem with my 106 last year and after much searching it turned out to be the nut at the top of the shock wasn't tight enough...best bet is to tighten the bollox outta the top nut and see how that goes before spending money and time on other solutions.
Posted 15th Oct 2009 at 01:16
I would say that you already have answered your questions. GKN one from GSF is a good route.
Posted 15th Oct 2009 at 01:26
hainesygti6
Thanks just wanted a bit of back up Whistle
Posted 15th Oct 2009 at 01:28
