Author Subject: Losing Power to Accelerate
chewitt
Well I seem to have a new problem with my car, a 306 XSi 2.0 16V Phase 2.
I have so far replaced the following:
Battery, ECU, Fuel Filter, Fuel Pump, Idle Control Valve, Spark Plugs, Engine Mounts, MAP Sensor and Coolant Temperature Sensor.
I still have a lambda sensor to replace but mine has seized itself to the exhaust manifold so taking to garage to get it done.
The problem I
306 LX 1.4 Phase 2
**Current Body Mods**
4 x 4" Exhaust System
Full B/Kit (Front, Skirts, Mirrors & Rear)
Bonnet with Scoop
Full Tinted Rear Windows
17" Alloys
Lights
Posted 14th Oct 2009 at 20:46
ken
coil pack?
Team Black Rallye Big grin
xbox live - Xx 7 kenny 7 xX
Posted 16th Oct 2009 at 14:53
chewitt
Is that the ignition coil?
Car has been fine for last 3 days, this happens quite regularly. Car will make me think it's all over and then will start doing for days on end until I do another ECU reset which will hopefully see me through another few days.
If it was the coil pack, would it be that intermittent?
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 16th Oct 2009 at 15:07
ken
hmmm i dunno then!
if its on then off thats wierd!
have you checked the plugs to see if there all working?
if not go get a diagnostics if that helps?
my car had similar problems i found out it was the map sensor i replaced that and she was fine.
Posted 16th Oct 2009 at 15:46
chewitt
Well I have changed the MAP sensor and no problems since. I just didn't want to hold my breathe until it does it again.
Why would a faulty MAP sensor cause that? I'm not even sure what it does! lol
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 16th Oct 2009 at 15:51
ken
its manifold absolute pressure.
you have replaced everything i can think of lol!
sorry bud.
have a search on google or this site incase anyone else has had problems like this
Posted 16th Oct 2009 at 15:55
chewitt
lol I know, if this doesn't fix it I really am out of ideas.
Will let you know how it gets on. Cars been ok for 3 days but it's usually a friday afternoon when the roads near my work are the busiest that it will happen, always as I'm driving over a junction too, end up sitting there like a duck, trying to inch car forward enough to get through it :/
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 16th Oct 2009 at 16:00
ken
oh deary me! hope you get it sorted
Posted 16th Oct 2009 at 16:51
mark-house
it certainly sounds like a faulty map sensor. if it does it again though i would get some one to run a diagnostic and see what error codes the ecu throws up. also id check for air leaks.
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 16th Oct 2009 at 17:14
chewitt
No error codes have come up, I have had it checked twice now.
Cost me around
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 16th Oct 2009 at 17:20
