Author Subject: Maxi track again
crf450
As some of you may have seen in the projects forum I've just completed my wide track beam for my car. The plan was to build the car with Maxi track but without the body kit.
After asking on here the general consensus of opinion was to add between 40 and 53mm per side on the rear track to do the job, but after doing this my track measures about 1565mm,not the 1628mm that's specified for the works Maxi's.
To adjust the rear to get wider track wont be a problem if I decide to go down that route but it wont be as easy on the front so I want to be sure I'm getting things right before I get my leg in it.
The only explanation I can think of is that Dimma decided that it wouldn't be sensible to widen the track as much as the proper Maxi's unless you used the proper Maxi beam.
Do any of the Maxi owners on here know what track they are running (track being the distance form the center of one wheel to the other)
Cheers Martin.
Quote "da g man!"
"You've only got to watch the "306 vs ringtaxi" video & you soon realise how good these mod's are! That guy is running Ash's 30mm ARB, Solid Mounts & 23mm Torsion Bars & some adjustments on the camber. Admittedly, the guy is an awesome driver, but it just go's to show how well these cars can handle with the right modification's
Posted 13th Oct 2009 at 18:39
birk
Rough measurments martin, but 61" on the rear and 62" on the front.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 13th Oct 2009 at 20:33
crf450
Ta for that Dan so yours is the same as mine is at the moment.
Quote "da g man!"
Posted 13th Oct 2009 at 21:23
birk
This mean your going even wider now, or sticking to what you have given yourself already?
07889376885
Dan
Posted 13th Oct 2009 at 23:57
crf450
Might go a bit widerBig grin.
Quote "da g man!"
Posted 14th Oct 2009 at 03:23
birk
Least you have the facilities to do so aye, your very lucky Smile
07889376885
Dan
Posted 14th Oct 2009 at 03:26
