Author Subject: MAP Sensor Replacement
chewitt
Where is the MAP sensor?
I have looked in the haynes and it says it is in the engine compartment attached with a bracket to the bulkhead.
Will I be able to see it if I look in engine bay or do I need to remove anything?
Car is an XSi 2.0 Ph 2
306 LX 1.4 Phase 2
**Current Body Mods**
4 x 4" Exhaust System
Full B/Kit (Front, Skirts, Mirrors & Rear)
Bonnet with Scoop
Full Tinted Rear Windows
17" Alloys
Lights
Posted 12th Oct 2009 at 21:12
justinaccurate
Not sure on your car but given it stands for
"Manifold Absolute Pressure"
I would speculate that its on the inlet manifold Thumbs up
Posted 13th Oct 2009 at 01:59
pugsta78
if its like the 6 inlet it will be a yellow plug by the round throttle cable bracket. Scrap that look in the FAQs under sensor locations..
Posted 13th Oct 2009 at 03:53
on the 16v XSi and 16v 1.8 XS plastic inlets they're on the underneath just above the starter motor, one 10mm bolt Smile
Haynes is correct that they're on the bulkhead for the 8 valve!
You'd need to read a section a few pages further on for the 16v engine.
Posted 13th Oct 2009 at 03:57
chewitt
Ok, will look for it there.
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 13th Oct 2009 at 13:31
chewitt
Ok, I have looked at the FAQ on sensor postions and my engine bay looks different. Obviously a gti-6 photo, not an XSi.
The MAP sensor isn't on the top as shown. I have had a look around but still can't see it.
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 13th Oct 2009 at 18:05
adam001
try reading a couple of posts higher...its under the manifold
Posted 13th Oct 2009 at 18:28
chewitt
Under the inlet manifold? Those 4 large tubes on the top of the engine?
*sorry, am not an experienced mechanic, pretty new to all this*
That's quite a job isn't it to get underneath it?
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 13th Oct 2009 at 18:33
chewitt
Swapped it last night.
Absolute nightmare of a job.
It was actually attached to the underside of the inlet manifold which meant I had to turn it completely around to get to the MAP.
Had to remove the injector rail etc to do this but eventually got it swapped.
Thanks for help.
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 14th Oct 2009 at 15:16
chewitt
Does anyone know if I should do anything to car now I have installed the new part?
Do I just do an ECU reset and I'm done or is there a correct thing to do once changing this part?
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 14th Oct 2009 at 17:27
can swap the MAP without removing the manifold.
Posted 15th Oct 2009 at 05:35
You could have just said well done instead of crucifying the poor bugger Razz
Posted 15th Oct 2009 at 05:37
looked like he had missed my post that's all LOL
I know they come off without removing the manifold as I was at bucklands one day at 5.30 getting a map sensor for the V6 and they wanted to shut the gate Laugh my ass off
Posted 15th Oct 2009 at 15:40
chewitt
On the XSi it is mounted underneath the inlet manifold.
On the GTi-6, it is located onto of the the throttle body.
Trust me, there was no way to the MAP sensor on my XSi other than lifting the inlet manifold to get to it underneath it.
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 15th Oct 2009 at 16:38
Rich E Forum Admin
Incorrect. The GTi-6 MAP sensor is on the top of the inlet manifold, on the right as you look at it from the front of the car.
Posted 15th Oct 2009 at 16:43
chewitt
Yeah, I knew it was on the top but wasn't sure if it was on top of the inlet manifold or throttle body.
I have only seen its location on the Sensors Location FAQ....it is in a different position on the XSi.
They obviously didn't think about people wanting to replace it when the XSi was made so they hid it underneath the inlet manifold, correcting it with GTi-6 by placing on top.
Crap bloody XSi.
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 15th Oct 2009 at 16:47
I have "borrowed" half a dozen off XSi manifolds, WITHOUT removing the manifold Wink
Posted 15th Oct 2009 at 21:47
chewitt
How did you do it then? Its underneath the manifold and you cant get in from the sides
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 15th Oct 2009 at 21:53
from the left side above the starter motor/behind the throttle body with a 10mm spanner Big grin
**No I haven't got small hands Razz
Posted 15th Oct 2009 at 22:05
chewitt
lol way to fiddly, would prefer to spend a bit of time taking off manifold than try and attempt that and end up dropping parts into engine bay
Even when it was still light outside it was pitch black under the manifold and too far under.
Thanks though, if I ever need to do it again (hopefully not!) will keep that in mind Happy
306 LX 1.4 Phase 2
Bonnet with Scoop
17" Alloys
Lights
Posted 16th Oct 2009 at 13:56
