| Author | Subject: hose leak |
306er
Senior User Location: Brize norton/ caterham F1 Registered: 28 Jul 2007 Posts: 888 Status: Offline |
Alrite lads, does anyone know what hose this is in the pic and is it easy to renew? cheers![]() ________________________________________ |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
It's the heater matrix hose. You'll need to remove/bend back the heat shield to remove it to replace or cut the end shorter if just perished at the engine end.________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
306er
Cheers mate, had to refill the coolent tank twice because of this it was p*ssing out when i pull over to check it.________________________________________ |
