| Author | Subject: Replacing Door Electrical Connector |
mwl001
Regular Location: Bolton Registered: 24 Jul 2005 Posts: 422 Status: Offline |
My drivers side speaker stopped working the other day and after a bit of investigation, I traced the problem to a broken wire at the electrical connector between the door and the car. There were 2 other broken wires, all very close to the moulded bit of the connector. A couple of other wires were showing signs of wearing so I decided to replace the connector using the replacement part available from Peugeot (Part no 6542.VQ for about |
looks pretty straightforward, how much free play is there on the loom and how much do you need to srtip off the inside of the car?personally I would have staggered the joins and soldered+heatshrunk them ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mwl001
Hardly any free play on the loom - which makes staggering joints difficult and is one of the reasons I went for crimps.Only need to strip enough for the crimp. If soldering - I would definately go for the new rubber cover. |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
I got a loom repair kit a few years ago and tried to get the driver's door boot as that was torn. They got me a rear door one. I took it back and they said the front ones were no longer available. I looked on Service Box and found that, although the driver's door boot was not shown, the passenger's one was, and that they are the same.________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
mwl001
That might explain why the local pug dealer told me it was included in the kit when ordered it but it wasn't there when I went to pick it up. |
steve h gti-6
Seasoned Pro Location: Carterton Registered: 04 Dec 2006 Posts: 1,583 Status: Offline |
Good FAQ me thinks and ill be using it when ive got to replace mine LOL________________________________________ "Gotta Love The 6"According to my wife i think the 6 is the fastest car in the world, perhaps she is right LoL ! |
dan gti-6
Regular Location: Winchester Registered: 26 Jan 2008 Posts: 112 Status: Offline |
Anybody know what pin 23 is for?? |
You can you get enough access by just releasing the check strap and chocking the door to stop it hitting the wing so you won't need to re-align it.________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
smegal
This thread desperately needs FAQ ing.________________________________________ Ex SC-6Now in a Megane R26 |
smegal
I will add 2 things though. Unbolt the single bolt in the hinge (makes putting the door on easier) ![]() I would solder the connections instead of crimping. ________________________________________ Ex SC-6Now in a Megane R26 |
rikky
as above, solder every time with some heatshrink, done mine last january and it's been fine. i crimped them in the past and they broke apart within a few weeks!________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
mwl001
Did mine about a year ago and no problems with the crimps, if you have a decent crimp tool (preferably a ratchet one) and decent crimps then it should be fine but there is also nothing wrong with soldering and heat shrinking. |
vts_tibi
Seasoned Pro Location: Nuneaton Registered: 27 Apr 2007 Posts: 1,194 Status: Offline |
I guess this connector can work with all of the 306s and Xsaras as all of the pins are in the connector, so you just use whichever pin you want.Nice find! I didn't know such things existed. ________________________________________ VTSbest 60' : 2.272 best 1/8 ET : 9.375 @ 74.42mph best 1/4 ET: 14.603 @ 97.047mph Team Trackday™ |
ablister
Senior User Location: fife Registered: 30 Oct 2005 Posts: 522 Status: Offline |
you can also get these as 'straight' connectors (unlike this 90 degree door loom) which work with the engine wiring loom where it joins the main engine bay harness ________________________________________ 306 rallye, Richard Longman enginerc10gt |
musclebeach
Seasoned Pro Location: Yorkshire Registered: 13 Aug 2006 Posts: 7,763 Status: Offline |
I've had it done on P45 HRM on the right side, NOT a job for the everyday amateur....we soldered and heatshrunk as said...took about 6 hours as there was only a very vague guide at the time and spent ages finding a pin map on the net that was actually some use!________________________________________ VW Golf GT TDI 115, 100k nooooooooooooooooooooo! |
Forum Admin
Forum AdminLocation: Always Watching Registered: 11 Dec 2002 Posts: 87 Status: Offline |
FAQd________________________________________ To contact the Forum Admin team, please click here to send a PM.Please also read the Forum Rules and the For Sale rules. |
This thread has been locked
