Author Subject: G/Box Mount conundrum . .
tom tom go
Tom Tom GONE!!
Wondered if anyone can shed any light on this for me. Trying to do the gearbox mount as I reckon its seen better days, and shifting is a bit stiff sometimes aswell. So thought ill do the cheapest easiest fix first . . . LOL
Took things apart, got to the plate under the battery tray. Now i know theres 4 bolts holding it down but i can't get to the two nearest the body for the bloody ABS lines been directly above them. Tried lifting them up to get a swan neck spanner over them but it can't get a proper grip of them Dry If i try pulling them away theres little give in them, reckon i could get the one nearest the bulkhead at a push but no chance on the other one, and im scared of snapping a line as i could do without that LOL
Pic's . . .
And pulling them out as far as i dare . . .
Experiance's/idea's Dunno
Cheers, Tom
Cherry RALLYE
Posted 10th Oct 2009 at 00:13
cwspellowe
Had this problem when I did Mat (oecken's) mount. We just used an open ended spanner coming from the battery tray side of the brake lines and took our time. Couldnt get much purchase on it so could only get 1/8th of a turn at a time. Helps if you pull the brake lines the opposite way to the pic you posted
Hope that makes sense
Bye bye Sundance Kid Sad
Posted 10th Oct 2009 at 00:18
lotek
theres 2 nuts holding the abs unit on , undo them and you will have enough movement to undo , or just pull them like a man, they will be fine just dont let pipes kink which wont be difficult to do.
Posted 10th Oct 2009 at 00:26
tom tom go
Tom Tom GONE!!
Cheers Cool one idea to try tomorrow then. The lines just creaked a bit when i moved them so I didnt want to push it just to get a socket over them LOL
Edit: aimed at cwspellowe LOL
But cheers lotek Thumbs up
Cherry RALLYE
lotek
ive had that plate off my car so many times, first time i undid abs unit . after that just pulled pipes to one side, they will be fine they havent actually got to go that far mate,
Posted 10th Oct 2009 at 00:28
lwgti-6
Exactly what i did last weekend. Worked for me. You will still feel like your putting strain on the pipes because in effect you are but you should be allright, of corse doing this is at your own risk lol.
I think the FAQ should be ammended somewhat.
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 10th Oct 2009 at 00:31
cwspellowe
Ha! We were too scared to pull on the brake lines too much so we fiddled around coming in from the side.
Or just jam a socket between them LOL
Posted 10th Oct 2009 at 00:32
tom tom go
Tom Tom GONE!!
Got it sorted today cheers chaps, moving the ABS unit made a big difference to access Thumbs up
Piece of p*ss to do, apart from that little hickup LOL
Cherry RALLYE
Posted 11th Oct 2009 at 01:11
oecken
as said on the day chris, ABS lines seem to be an after thought (shite, now where can we put those.. Dunno, oh that'l do LOL)
Posted 11th Oct 2009 at 01:36
cwspellowe
Aye, they could have run them more to the side to allow better access surely?
Some designs are just daft
Posted 11th Oct 2009 at 04:47
