Author Subject: Now i know this has been posted A few times
rich306
http://www.306gti6.com/forum/showthread.php?id=84569&page=last
http://www.306gti6.com/forum/showthread.php?id=81627&page=last
http://www.306gti6.com/forum/showthread.php?id=70500&page=last
Ive been looking through the above threads 'Trying to do my Research' and found out nothing that i needed to know.
As the Above people, i'm doing a conversion on my Xsi and apart from knowing that the blocks are pretty much the same, i also know that i need to replace;
Inlet Manifold (on way in post)
Exhaust Manifold
Ecu
And Cams
However..... I went to the scrappy the other week, found a 406 with what appeared to be a 2.0l Xsi engine in it and found that it had the 16v badge stamped on the Rocker Cover. I compared this to my Xsi Rocker cover (which does'nt have the 16v Badge) and found out that the bolt fixings are different which indicates to me that i would need to replace the entire Cam carriers etc.... therefore suggesting to me that the GTI 6 engine must be pretty much the same
taking this into account, how far would i have to go to avoid placing a GTi engine into my bay??
And also would the GTI head be a straight swap?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 7th Oct 2009 at 04:46
mark-house
Which engine do you have 8v or 16v?
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 7th Oct 2009 at 14:02
rich306
16v engine.
- Top Tip!!!
Posted 7th Oct 2009 at 14:46
rallyestyle
Unsure If you avoid buying one and taking it anywhere near the car then you should be safe Yes
Just Drive It
Posted 7th Oct 2009 at 14:52
rich306
lol, i like a challenge hence why doing a conversion. But surely if the block is the same then it should be a straight swap on the Cylinder head right?
- Top Tip!!!
Posted 7th Oct 2009 at 14:57
