also how much work would it take to remove the ABS unit to non ABS. just a thought.
| Author | Subject: replacing bearings. |
slywhite
Regular Location: hibaldstow Registered: 28 Aug 2006 Posts: 351 Status: Offline |
hi all, is it possible to replace the front wheel bearings myself or is it a garage job, just fitted new coilovers and found out that the front drivers side bearing has seized, had to chop my droplinks to get them off and offside ABS sensor snapped inside hub trying to take it out, so not going to well.also how much work would it take to remove the ABS unit to non ABS. just a thought. |
hismastersfinger11
Regular Location: swindon Registered: 29 Nov 2007 Posts: 434 Status: Offline |
i just took my hub to the garage think thats the most easy/cheapest option mate.i had droplink bother too anglegrinder sparks look so good in the wheel arch imo ________________________________________ This site is my mechanical bible, Thank-you everyone!! |
slywhite
i used a windy gun and grips once the plastic bit was out the way, |
hismastersfinger11
sounds like you have the same luck as me everything is siezed but then most of it has been replaced now not much siezed stuff left lol good luck with the bearing.also ask the garage how much the bearing is as gargaes have soooo tried to rip me off on bearing prices before!!! ________________________________________ This site is my mechanical bible, Thank-you everyone!! |
slywhite
will do fella, thanks for info. i am doing the same now, replacing everything as i find it has worn or siezed. |
hismastersfinger11
i think its the magic 80-90,000 miles for me by 100,000 it'll be a new car bar the shell lol still should be good for another 100k then lol________________________________________ This site is my mechanical bible, Thank-you everyone!! |
slywhite
just another quick question if anyone can help, took the bearings out of both front hubs but it has left the runners/seat in, do they come out or stay in? |
you need to press that bit out too, looking at the new bearing would have told you that ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
slywhite
would do but dont have new ones yet. ordered today. |
slywhite
done the bearings today and all went well. everything went back together with no problems, fitted new drop links and nuts and bolts where needed, and coilovers with new top mounts and bearings. got it all done and drove the car afterwards to find that my steering wheel is turned slightly to the right. wheels are straight and all but slight pull to the left which i think tracking will sort but not sure whats gone wrong with steering wheel. any ideas please do say. |
greenbelt
Seasoned Pro Location: How's Life In London? Registered: 23 Apr 2006 Posts: 1,961 Status: Offline |
It will be the tracking ![]() You need to remember that you have moved/replaced everything attached to the hubs. The tracking will still be set to how things were before you did the work. Tired droplinks, top mounts, bearings, struts, springs etc... Try getting it tracked and start on a fresh page so to speak ________________________________________ Standard Black 6Black HBSC6 |
slywhite
will do, fella. thanks for that. will see how things are after that. |
davidmartin
Seasoned Pro Location: Beautifull Ystalyfera Registered: 21 Oct 2006 Posts: 3,316 Status: Offline |
maybe a good idea to change your balljoints before you get it tracked,if you havn't allready that is.________________________________________ pet hate, the cat |
slywhite
cheers for that mate |
