Can heat then C02 be used to crack any seized lines loose like with seized nuts? Also aided with lots of WD40 or simular?
Thanks
| Author | Subject: Removing brake flexi lines |
kezman7
Senior User Location: Castleford Registered: 20 Feb 2009 Posts: 762 Status: Offline |
Im swapping my brakes for some bigger ones but i need to swap them myself. I have bled brakes before but i havnt delt with the hoses. Whats the best way to remove the flexi hoses from the car side (still connected to caliper) without damaging them as ill need to reuse them.Can heat then C02 be used to crack any seized lines loose like with seized nuts? Also aided with lots of WD40 or simular? Thanks |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
Get proper brake spanners and take your time.Its realy easy to damage the unions. |
kezman7
I have had alook on demon tweeks and theres a choice of many difference sizes, What size will i need for the Gti6 lines and also the other brakes are from a different peugeot but not sure which |
11mm brake pipe spanner, 17mm and 13mm maybe 14 sometimes for the rest.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mr swampy s16
Halfords do the spanners for the pipes |
