Author Subject: Bias box help
chris with a pug
My new bias box arrived today and am having a little trouble getting the master cylinders to fit.
Do you have to cut the threads shorter or do you space them out with the extra bolts they supply?
I know a few of you have these fitted
Posted 6th Oct 2009 at 00:04
chris with a pug
Anyone?
Posted 7th Oct 2009 at 12:21
midlife
A picture is worth a thousand words ChrisWink
Cool
Team 330™Cool
Team "no front end or engine"
Posted 7th Oct 2009 at 17:24
chris with a pug
That is as much as I can wind the balace bar ends down the M/C's, with the nuts on.
Really the options I can see are not using nuts to lock them off and then trim the threads so can get the balance bar in.
run a dye down the shaft to extend the thread so I can get a nut on and will still need to cut the tread the other end though.
Or space out the M/c from the front of the pedal box.
Not sure I wanna do the last one to be fair
Posted 7th Oct 2009 at 22:06
Looks like the threaded rod from the master cylinder is supplied long to allow you to tailor it to suit your individual apllication. It will need cutting down a bit, but before you break out the hacksaw just yet do you want me to get Martin to take a look as he had a similar setup on the Westy?
Posted 8th Oct 2009 at 00:57
chris with a pug
yeah, that would be cool, will need something doing
Posted 8th Oct 2009 at 01:01
