displaying posts 1 to 25 of 33
Author Subject: 2.0 8v turbo problem
pugheaven
hi my mate has the 2.0 8v turbo engine in his 205 which a few of you may have seen at the pompey rr day.
Its been running ok but then he put an adjustable fuel pressure reg on, he set it for 3.5 bar and then the car started to mis-fire at 3k rpm.
He then took it off and it still misfired, so he got a new standard fuel pres reg,spark plugs new coils new injectors and its still doing it.
He has also checked icv and was told that it wont be the crank sensor or lamba.
Any one have any idea what else it might be.
Thanks
Ollie
Posted 2nd Oct 2009 at 00:25
6neil
has he got a fuel pump that can supply enough fuel? upping the pressure for a bit may have killed the standard one off? not sure what the standard pressure is tho?
Posted 2nd Oct 2009 at 00:33
sosmotorsport
does the car rev past 3k
if so is there any mis fire after 3k when on boost ?
SOS Motorsport
www.sosmotorsport.co.uk
450bhp 205 16v Turbo
www.facebook.com/pages/SOS-Motorsport/159917677353556
Posted 2nd Oct 2009 at 00:49
pugheaven
yes it does it as soon as the boost kicks in. Its only runnin standard boost and has got an uprated fuel pump. Thanks ollie
Posted 2nd Oct 2009 at 01:34
sosmotorsport
have u checked the vacuum pipes going to map sensor etc ?
SOS Motorsport
Posted 2nd Oct 2009 at 01:37
allesclar
no leak is there?
Team allesclar ®
Posted 2nd Oct 2009 at 01:41
pugheaven
he hasnt checked them yet as he doesnt know where they are, he is new to that engine and i dont know anythink about them so where would he find the map sensor and where do the vacum pipes go to, inlet mani?
Posted 2nd Oct 2009 at 01:48
sosmotorsport
should be a pipe on the top of the inlet beside the one that feeds the fuel reg
the pipe will feed the map sensor which is in the 8v turbo ecu make sure he aint split it or took it off by miss take
SOS Motorsport
Posted 2nd Oct 2009 at 01:52
pugheaven
ok thanks.
ill get him to have a look, if not what else could it be.
Posted 2nd Oct 2009 at 01:59
sosmotorsport
if he has changed all the above as you said am pretty sure its a map sensor fault hard to say without seeing it only speaking from experience
plug leads if not tried that
SOS Motorsport
Posted 2nd Oct 2009 at 02:04
pugheaven
ok mate ill get him to check, will that be picked up on diagnostics think he is takin it to his nearest garage tomoro
Posted 2nd Oct 2009 at 02:07
sosmotorsport
does he have a diag port wired in to the 205 with that engine ?
SOS Motorsport
Posted 2nd Oct 2009 at 02:09
pugheaven
probably not!! lol
Ill let you know how he gets on.
cheers anyway
Did you sell the turbo,cam and kms from your old engine?
Posted 2nd Oct 2009 at 02:12
sosmotorsport
no worries if he gets stuck ill fire u as much ideas as i can at u let me know how he gets on
ye mate sold the lot a while back was a good match of stuff i had worked very well
SOS Motorsport
Posted 2nd Oct 2009 at 02:13
pugheaven
He was putting the engine in when you had that for sale, he still kicks himself for not buying it, some times i kick him aswell just for the fun of it tho.
will keep posted mate.
Posted 2nd Oct 2009 at 02:16
Has he got the right fuel reg? I was under the impression that when using a turbo you needed a rising rate fuel pressure regulator that increased fueling as boost rises, this is done by taking a pipe from the inlet manifold to the diapragm side of the regulator. I have an FSE reg and there is a small tail coming out of the top of it for use on boosted engines.
Make sure he reconnected all of the pipes when he changed the reg, and that everything that should have been there in the first place is still present.
Posted 2nd Oct 2009 at 02:19
pugheaven
he has gone back to the standard 3 bar (i think) one to try and get rid of the problem
sosmotorsport
ye would have been a good buy and good power for the money
sometimes wish i had kept it LOL
SOS Motorsport
Posted 2nd Oct 2009 at 02:33
pugheaven
well if you want to sell the 16v turbo let us know. i wish!!
Posted 2nd Oct 2009 at 02:37
sosmotorsport
everything is for sale at a price Cool
how come you never went turbo Sad
SOS Motorsport
Posted 2nd Oct 2009 at 02:43
pugheaven
well i got taken of shift at work and afgan tour was put off for a while so didnt have much money.
just brought euan's throttle bodies.
goin to afgan for four months in march so might look into a new engine then but want to build the n/a 6 first.
Posted 2nd Oct 2009 at 02:49
sosmotorsport
ah got ya
ye a knew u bought euans throttle bodies they will work well on your engine
afgan for 4 months doesnt sound as good tho hahahah
SOS Motorsport
Posted 2nd Oct 2009 at 02:58
pugheaven
well the money is stupid so cant turn it down, get good pay as im not in services.
im treatin my self when i get back.
Posted 2nd Oct 2009 at 03:04
sosmotorsport
what we do for money lol
treat your self good then hahahahahah
SOS Motorsport
Posted 2nd Oct 2009 at 03:06
pugheaven
if only you where closer and not the other end of the island, wouldnt mine knowin how you get your money, male escort? lol
Posted 2nd Oct 2009 at 03:09
