Author Subject: Brake problem
marksorrento205
My rallye has failed the mot on low efficiency of the rear right brake. I have fitted a new caliper and its not long (1000 miles +) had discs and pads but its failed again. Before breaking down the system again and shelling out more tin any one got any ideas? I have kinda ruled out the master cylinder on the basis the front brake on the same ciruit is operating as it should and getting a good reading. The compensator on the rear beam is very free to move too - I know this does not rule it out though. Bloody pug rear brakes LOL
Posted 1st Oct 2009 at 19:24
chris with a pug
is the carrier clean where the pads slide along?
Posted 1st Oct 2009 at 19:48
marksorrento205
Yeah its had a very good wire brushing
Posted 1st Oct 2009 at 20:12
check that the caliper moves side to side on the sliders.
Posted 1st Oct 2009 at 20:13
marksorrento205
It does mate. I know it not a dead cert but its a recon one. The piston also moves freely too.
Posted 1st Oct 2009 at 21:15
marksorrento205
Could the abs unit cause this?
Posted 2nd Oct 2009 at 03:29
dr-evil
Is the replacement rear caliper the correct sized piston ? The 6/Rallye has bigger pistons - most part suppliers and garages don't know or care. I had the same trouble as you with my previous six - rear brakes failed, new discs, pads and cables fitted by a cross eyed muppet still failed, 'needs a new caliper' came the cry still failed, bed in the pads i cryed then it past - picked it up after a week of the garage/mot centre buggerin about and 300 quid and the brakes were jammed on because the clown had fitted the cables on the wrong sides LOL
So as long as the calipers all good, adjust the cables correctly (remove them from caliper, pull lever back, pump the brake pedal a couple of times, refit cables, adjust up till your assistant can feel a little resistance while rolling the car back and forth) then bed the pads in with three or four hard stops before allowing to cool.
If they still don't pass after all that then the pads and correponding areas of the carriers will need a quick tidying to allow the pad to slide cleanly.
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 3rd Oct 2009 at 01:53
lotek
What he said , or fit Drums lol
Posted 3rd Oct 2009 at 09:44
smegal
Mine kept failing on the rears but that was both not one. Mine was the comp valve. I'm guessing it's caliper related. You tried re bleeding it?
Ex SC-6
Now in a Megane R26
Posted 3rd Oct 2009 at 18:37
marksorrento205
Yeah Sad I have bled it a few times now. Even tried taking if off and holdig te caliper up higher and without the pads in, pump the pedal until the piston pops out a bit then oper the bleed nipple and put the piston back in etc
Posted 4th Oct 2009 at 21:40
robthe6
whats the disc's and pads like. is the disc glazed over. try spraying some brake cleaner on the pads and disc. an i mean really lap it on. also check the one of the hand brake cables isnt pulling more then the other. you could have a dodgy compensator. but also could be shit in the caliper.
have the caliper on the car as normal, with pads and everything as how it should be. have someone put there foot on the brake. crack the nip open. slowly pump 3 times and when there down on the 3rd pump close the nip. come off the brakes. wait, then press the pedal as hard as you can and i mean really f*ckin hard. and open the nip and close straight after the pressure has gone. that should shift anything in there that shouldnt be. then clean off with brake cleaner and test.
also im not saying you dont know how to bleed brakes just this method has worked for me.
1997 ph1 bianca GTI6 - The looker
1996 ph1 Sigma GTI6 - Dead Sad
1999 Red Rallye - The Daily
2005 Nissan Navara D40 - Family car
1968 Mustang Coupe - The dirty little secret
Put ya foot down, put ya foot down we'll loose em easy!
Posted 5th Oct 2009 at 08:10
marksorrento205
Hey mate, any help will do at the min LOL
Posted 5th Oct 2009 at 13:01
