Author Subject: Help needed for top mounts
benn25
Iv decided to give changing the top mounts a go. But iv made the fatal error of loosening all bolts at the top so the strut has just come away. Ive undone the hub bolt but because obviously the strut has come off i cant actually get the blasted thing off. I am having difficulty with the spring as its decided to curve on me. So when compressing the springs do i have to attach from top to bottom or can i attach from say the 2nd tier to the bottom so i can angle the strut out and it will still work. Ive made a complete hash of the whole thing, so any help ir ideas to complete this would be much appreciated.
Posted 28th Sep 2009 at 22:04
cress87
The best advice I can offer is be careful you don't kill yourself. Springs/spring compressors are not the sort of thing you can afford to mess around with.
Posted 28th Sep 2009 at 22:06
benn25
I appreciate your concern my man but that doesnt answer my question. The springs arent tort or anything. If i can put the compressers a little bit lower then i can probably get the thing out. Just need to know whether i can do that or not?
Posted 28th Sep 2009 at 22:10
cress87
Put the spring compressors as close to the top and bottom of the spring as you can. Compress them evenly on both sides and do not remove the top nut until there is no pressure on the top mount and the springs are held securely.
Posted 28th Sep 2009 at 22:13
midlife
PLEASE take it to a garageNo No
Cool
Team 330™Cool
Team "no front end or engine"
Posted 28th Sep 2009 at 22:38
considering you couldn't jack the car right i would avoid springs and topmounts like the plague LOL sorry but i have seen springs go through garage roofs so i would step away. they need to be as close to both ends as possible as cress says
Posted 29th Sep 2009 at 00:27
smithers
I take it youve got a compressor on both sides of the spring?
Your probably better taking the entire strut out with the hub attached now, if you can get the driveshaft nut of that is.
As stated be very careful though Thumbs up
1997 Black GTi6
smithers205 at hotmail.com
Posted 29th Sep 2009 at 13:58
jimmy_boy
The silence is worrying...
Unsure
GTI-6 & Rallye
Rallye gets sideways in the wet at Snetterton Ninja
Posted 6th Oct 2009 at 00:03
darkgti6
This may seem like a good idea and it is - IF the driveshaft splines arent seized! Ive mushroom shaped the end of a nearside driveshaft before now attacking it with a sledge hammer. It took a pounding believe me but did shift in the end! I then had to grind down the end of the shaft with an angle grinder to pass it through the hubRoll eyes
You have been warned!Whistle
Team Peugeot Sport 308 Gti�
Posted 7th Oct 2009 at 00:04
instead of taking the hub off with it, why not just split the shock from the hub and take it all this way?
have you fixed the garage roof yet
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 7th Oct 2009 at 21:30
greenbelt
Unsure
...very worrying
Sad
Standard Black 6
Black HBSC6 Smoke
Posted 8th Oct 2009 at 00:17
denwar
u dont need to split the hub, just undo the pinch bolt at the bk of the shock and lift the shock out of the hub, you need to undi the braket thats bolted to the hub which holds the abs sensor and the brake hose in place. shoodnt have undone the top 1st until complete strut is out of car, once you have the complete strut unit out, then put your spring compresors on, and remove top mount, replace, and then refit complete strut unit. crazy man.... dont kill yourself, a loaded spring is seriously powerfull, and will brake your jaw.
denwar
Posted 13th Oct 2009 at 01:10
