Author Subject: speedo rev counter temp fuel
grumpychef
The Rib Man
afternoon guys well i have had a quick scan and cant find the answer! i have lost speedo, rev counter, fuel guage, and oil temp, water temp still works! i am assuming it is a fuse but not sure and cant find the relevant fuse in "the book". can anyone shed any light on this quick answer would be very much appreciated as not having a speedo could be a seriuos concern the way i drive!
thanks in anticipation.
Formally team BLAZE now Team bianca recuperating from multiple organ failure nicely!
items replaced so far, clutch, cambelt etc, radiator, exhaust, most of front running gear, wish bones, drop links, ball joints, track rod ends, bearings, brakes, calipers, discs, and pads, brake lines, front springs, brake balance compensator thingy, hand brake cable, throttle cable (twice), coil pack, door handle, windscreen, wipers, head lamps several sensors and bulbs Dry .rear beam new throttle cable, new battery. .......... yeah man, team money pit! but shes still rollin!
Posted 27th Sep 2009 at 18:14
grumpychef
The Rib Man
surly someone must have an idea?????
Posted 27th Sep 2009 at 18:29
abergavenny_306gti6
phase one or two ?? and do you have the 13 fuse block or the 24 ??
Posted 27th Sep 2009 at 18:32
grumpychef
The Rib Man
sorted silver shunt fuse Blush !!!!
Posted 27th Sep 2009 at 18:37
