displaying posts 1 to 25 of 39
Author Subject: water temp upto 110
sixysix
Hi all,
Just a quicky as I have not had a chance to have a look in the light yet.
Driving back home today, the water temp sits normal when driving, but when I hit a bit of traffic, the temp starts to rise to around 100, then upto 107/110 before coming back down to around the 100 mark and then will rise and fall while in traffic until I get moving again which cools it back to around 90.
Had a quick search and I take it that my low speed fan has packed up most likely?, as the other fan is obviously cutting in at 107 to cool it down a bit.
Anyone think this is right before I go hunting for fans, or any other idea's??
- Mark Smile
Take a look
Posted 27th Sep 2009 at 01:50
smighall
Smeg-all
How long have you been on here Blink
Meh
Posted 27th Sep 2009 at 01:56
birk
LOL Im sure thats normal.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 27th Sep 2009 at 02:15
sixysix
I know what your saying guys, don't make me out to be a complete tard! LOL
But my temp would get to around 100 in traffic and not fluctuate from there until moving again and it would drop back to normal temps.
As it is atm, in traffic, the temp will rise and fall between 90 - 110 about 3-4 times in 5 minutes.
Whatevers happening, it's not normal, and think I have only ever seen the temp get to 110 once in 7 years with the 6.
Water and oil are both fine btw
Take a look
Posted 27th Sep 2009 at 02:43
jimmah
this is exactly what happened to me, but dont know if sorted it yet as still rebuilding the engine bay. If it happens again with all my new bits on, it'll more than likely be the fans, or relays, as i will be chucking a new fan temp switch (brown one on stat).
1998 (S) Phase 2 Diablo Red GTI-6
Posted 27th Sep 2009 at 17:15
anth
sounds normal mate,
unplug the brown sensor the fans will come on slow speed then full speed after a few seconds.
Bare in mind that them temp gauges aren't always accurate.
Posted 27th Sep 2009 at 17:57
puglover Banned!
doesn't sound normal to me but nothing drastic
you might need a new rad and coolant change, check the fans and the thermostat.
with nissens rad and some water wetter it never went above 100 even in traffic.
what you describe is probably normal average operation though.
Posted 27th Sep 2009 at 18:06
lwgti-6
mines the same chap, tried everything to resolve this problem, new nissens rad, fresh coolant, bled the system twice, had the head rebuilt, the list goes on...been doing it for about 9 months now so i know its not the gasket. Just remove the brown sensor behind the drivers headlight and bridge pins 1 and 3 to control the fans manually using the air con button in the car....thats assuming your cars aircon dosent work of corse...lol
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 27th Sep 2009 at 18:05
scoty18
Sounds the norm. try changing the coolant, flushing out the radaitor and blowing out the crap stuck between the ins. might make a wee bit diffrence
  • TEAM DIABLO!!
  • Posted 27th Sep 2009 at 18:54
    jpmatrix
    sixysix wrote:
    Hi all,
    - Mark Smile
    Sounds very similar to my problem and it is most likely that 1 of your fans is not working.
    There is not a low speed fan, its set up so that when the thermostat hits 97c both fans come on in series so they only get 6volts . If one fan is not working then the curcuit wont work (broken curcuit). This is why the temp goes sky high and when it reaches 107c then the curcuit changes so the fans change to a paralell curcuit both fans get 12volts ( high speed fans), but only 1 will work because one of them is foobered.
    Best thing to do is to test both your fans. Obviously pulling the brown plug should make both of them go on at high speed ( parallel set up). I got a fan for
    Posted 27th Sep 2009 at 20:24
    sixysix
    Cheers for all the replies guys,
    Will have a look tomorrow morning for the fans first as my gut tells me thats the most likely cause.
    If I had known that the balljoint on my icecream van would snap and grind to a halt and leave me stranded for 4 hours, I would not have bothered and could have got the car sorted instead Roll eyes
    Take a look
    Posted 28th Sep 2009 at 04:11
    sixysix
    Right then, just had a look and it seems that my car only has the one fan but cowling for 2 fans Unsure is this normal on a phase 1 as I'm sure everyone else has two fans on the rad??
    Let her run to warm up, get upto 97 and no life from the fan, once it hits 107, it cuts in as normal and temps drop back down as they should.
    Does this mean that my single fan should run at different speeds depending on the heat or could this be a sensor issue as it's not cutting in early enough for normal opperation??
    Cheers all, Mark Smile
    Take a look
    Posted 28th Sep 2009 at 18:14
    al4x
    yes the second is if you have aircon fitted
    how long have you been on here Whistle LOL
    Posted 28th Sep 2009 at 18:58
    sixysix
    Doh anyone got a shovel I can use Laugh my ass off
    Take a look
    Posted 28th Sep 2009 at 19:08
    sixysix
    Hi again guys,
    Not had a chance to look at the fans until today.
    Fans do not come on until temps hit 107, so obviously the low speed is not kicking in at all.
    Went to double check by unplugging the brown CTS sensor and my phase 1 does not have the sensor fitted Sad
    Anyway, checked fuses 33 & 34 in engine compartment and they are fine so thats the easy parts checked now.
    Any suggestions in order as to most likely cause?
    Relay, bitron, motor, or something else??
    Cheers guys, I have had a good ol search and am still a bit lost Roll eyes
    - Mark Smile
    Take a look
    Posted 24th Oct 2009 at 18:28
    jimmah
    Mine is now running between 80 and 90, new sensor and nissens rad.
    Posted 24th Oct 2009 at 19:22
    fergusxsi
    same wit my xsi 8v i put d heat on helps abit but my rad has gaps between the cores round the bottom near the grill!!
    Posted 24th Oct 2009 at 19:30
    matt_gti
    Both my fans come on at about 107 on slow and it will slowly go down form there. Odd yours only has one.
    306 GTI-6
    205 GTI-6 Project
    205 1.6 GTI - RIP
    205 1.9 TT - RIP
    E39 535i - Daily driver
    *Newest edition* E60 M5 5l v10 - The weekend car Smile
    Posted 26th Oct 2009 at 02:19
    chris with a pug
    WTF is wetter water?????????
    Posted 26th Oct 2009 at 02:42
    SteviePut
    "Water wetter" is an additive that lowers the surface tension of the water so it absorbs more heat - or something along those lines - apparentlyWink
    Posted 26th Oct 2009 at 02:50
    chris with a pug
    Fair enough. never heard of it
    Posted 26th Oct 2009 at 02:56
    SteviePut
    Shouldn't need it anyway. There's a problem elsewhere if you doSmile
    Posted 26th Oct 2009 at 03:04
    dan_s16
    sixysix wrote:
    Hi again guys,
    - Mark Smile
    Sounds like the low speed fan resistor has died. If you look on the fan housing somewhere you should find a metal canister which is the resistor used for slow speed. when they fail they tend to fail open circuit so the fan doesn't work until it switches to high speed.
    I believe it's the same resistor used for the dim dip headlights on a phase 1. I had a quick look for a pic of one so you know what i'm talking about but couldn't find one so I will try and take a pic of one of mine tomorrow.
    Posted 26th Oct 2009 at 03:05
    sixysix
    dan_s16 wrote:
    sixysix wrote:
    Hi again guys,
    - Mark Smile
    Cheers Dan, that would be great Big grin
    A friend did mention that it could be a resistor, but would only go looking there if I had to take the front off to check the relays.
    I take it, I could get another same rated resistor and solder it in place of the old one ?
    Either that or new fan time I guess Roll eyes
    Take a look
    Posted 26th Oct 2009 at 03:28
    dan_s16
    It won't need soldering it just unplugs. I'm not entirely sure where they are located on the fan housing as it was a few years ago I removed mine to fit a double unit for the a/c I was fitting at the time but I believe they are easyish to get to as they are in the air flow to keep them cool.
    Posted 26th Oct 2009 at 04:22
