The low oil pressure light has never come on when the engine is running only when it stalls or before I start it, But I know it's serious if the oil pressure gets low enough to bring that on.
Could it just be the sender/gauge playing up or could I be heading for big bills in the near future?
Oh I have been using Total 10W40 and a genuine Peugeot oil filter. I may start using 10W50 if I can find any that doesn't cost a fortune. Possibly going to change the oil next week as I can't remember how many miles it's done since I last changed it (no more than 5k though)
It does have a small oil leak which as far as I can tell is coming from the dipstick tube join to the block (down the back of the engine on the S16) or it may be coming from the crank shaft seal, I'm not 100% sure, I was going to get it checked next month when it has it's MOT as if it's the crank seal I will need to get the cam belt etc. changed too.
dan_s16
SO i'll try and get 5 litres during the week and change it. Then I will see how the pressure is and report back. I have got another oil pressure gauge I can screw into the block if I really have to so I may try that too and see if it says the same as the standard one.
