Author Subject: wont tick over???
panks blaze
i have recently fitted some pt82 cams,but wen i start it up,the engine wont tick over.i have replaced the air flow valve,but still no joy.the timing is correct and it was running ok before i put the cams in.could the inlet or outlet pulley be slightly out by a few degrees?would i need to get it re-mapped?any info would be much appreciated.rich.
black and gold
Posted 26th Sep 2009 at 17:53
bulldogs
Try reseting the ecuUnsure
Posted 26th Sep 2009 at 19:18
panks blaze
iv done that.
black and gold
Posted 26th Sep 2009 at 19:55
marra
a remap
Posted 26th Sep 2009 at 20:03
Ben_gti-6
adjust the cable to bring the idle up until the remap
More than happy with my re-mapped T5
Posted 26th Sep 2009 at 20:15
ryangti6
Will the engine run okay if you give it a bit of throttle? If it will then its probably just because you havent had it mapped.
If it wont then before trying anything else I would check your piston/valve clearance as I'm sure I have read these PT82's have too much lift to fit in a standard engine.
Ryan
Posted 26th Sep 2009 at 21:01
panks blaze
engine runs fine while out driving,not tapping or anything.just dies when i come to a junction or pull up.
black and gold
Posted 26th Sep 2009 at 22:50
bulldogs
I have been told the ecu should self map to camsUnsure .Speak to Colin at pug performanceWink
Posted 26th Sep 2009 at 23:01
