Author Subject: Pulling to the Right?
adamski_306
I took my car to the garage today, as it pulls real bad to the right. I thought the tracking was out as i've recently had the front lowered.
They checked it and said the alignment was spot on, took it for a drive and it still pulls. They stuck it back on the ramp and checked out the suspension, and couldn't see anything obvious, such as bent wishbones, but he suggested the top mounts?
Anyone got any thoughts?
Cheers,
Adam
Posted 26th Sep 2009 at 16:09
Rich E Forum Admin
Sticking brake caliper? Check the drivers side front and rear.
Posted 26th Sep 2009 at 16:23
monkeyman
The first set of springs I got for mine were too short / soft and the car used to pull to the left slightly. I was going to get the tracking done, but after fitting a set of longer / harder springs, it disappeared.
How much is your lowered by?
Forum Search Clicky
Posted 26th Sep 2009 at 18:12
adamski_306
It's been lowered 30mm a the front, and nothing at the back as of yet.
Posted 26th Sep 2009 at 19:29
fletch
Track Head
Could be, worn wishbone bushes, differences in tyre pressure and/or tyre wear, ream beam mount bushes.
Posted 26th Sep 2009 at 19:40
Could be the balljoint is knackared or is moving around in the bottom of the hub. I'd check the hub pinch bolts asap to start with.
Posted 28th Sep 2009 at 00:43
mabgti
NV motors
check the track length front to back on both sides... could be a misaligned beam or bent subframe.. top mounts are likely too.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 28th Sep 2009 at 02:00
adamski_306
Cheers for the advice everyone.
After getting my Dad to take the suspension apart on sunday, we've discovered the drivers side top mount is knackered. Where can i get one, and are they handed?
Posted 29th Sep 2009 at 13:58
Don't think they are - usual suspects GSF, ECP, local factors, Peugeot...
Posted 29th Sep 2009 at 23:35
adamski_306
Just a quick update, i've changed the top mount and bearing and it appears to have cured the problem.
Thanks for all the help, advice Thumbs up
Posted 24th Oct 2009 at 22:28
cahillscornerflag
This sounds promising then, I've had the same problem and I've got some new mounts and bearings yet to fit. If it ever stops raining.
'00 Astor Grey GTi-6 - Regretfully sold!
'89 Onyx Black 205 GTi 1.6
Posted 25th Oct 2009 at 00:42
