Author Subject: No Sidelights
tweedie
Well i have been driving around with no front sidelights at all and my rear passenger side has been off too... Replaced the bulbs but i get nothing.
Can anyone help? I have checked all my fuses but still nothing has blown.
Blink
Posted 26th Sep 2009 at 06:14
tweedie
Anyone had this issue?
Posted 27th Sep 2009 at 04:59
smithers
Have this exact issue. Drivers rear sidelight works fine.
Appears to have been some water in the passenger rear so going to swap out the internals of that first.
Any ideas how this would affect the front sideligths though? Thumbs up
1997 Black GTi6
smithers205 at hotmail.com
Posted 24th Nov 2012 at 13:31
rich306
It shouldn't technically affect the front, but considering it does i'm wondering whether water has got in with the Relays located Top right in the engine bay.
That could be one of the many explanations to this problem.
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 24th Nov 2012 at 13:42
I know that the front sidelights and one of the rear sidelights are on the same circuit, so I am guessing that the fuse for this circuit is blown, even though it may *look* ok.
Electrically test it, rather than just a visual check. Thumbs up
Posted 24th Nov 2012 at 14:25
tvrfan007
This. Whistle
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 24th Nov 2012 at 14:52
smithers
All fuses ok, continuity across them all.
Plugged the drivers side cluster into the passenger side and it works so looks like the cluster has a short.
Been to 5 scrappies none. who have a 3061
wanted add going up in a sec. .thumbsup
1997 Black GTi6
Posted 24th Nov 2012 at 15:13
smithers
Scrap my last -
No blown fuses - checked continuity across them all. (Believe it is fuse 4 for the front sidelights and rear passenger.)
Both clusters are working (tested on drivers side) so not shorted as i previously thought.
Now the interesting thing is that I have no voltage at any pin on the plug at passenger rear and both fron headlights.
Any other ideas?
1997 Black GTi6
Posted 24th Nov 2012 at 16:36
rich306
I'm assuming you have tested every Pin with a solid earth to confirm on no voltage then?
I'm wondering if you have a dodgy earth, check out the earth points on the chassis leg, clean them up and try again.
- Top Tip!!!
Posted 24th Nov 2012 at 17:23
smithers
Yes checked every pin with sidelights turned on at the stalk.
Earths sounds like a good shout - job for tomorrow as it's baltic up here today.
I've found a few posts of people with the same problem but nobody has posted a resolution.
Cheers for the help so far Thumbs up
1997 Black GTi6
Posted 24th Nov 2012 at 17:36
allyrennie
If your needing any bits from the scrappies sir let me know, burnside near me has a ridiculous amount of 306's in just now!!!
Rules and tools of life:-
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape
Team Roofrack.........
Posted 24th Nov 2012 at 17:46
smithers
All sorted - finally got my Autodata working so got a hold of the wiring diagrams.
Ended up being fuse number 9 that was blow but it was belling for continuity across the 2 terminlas on top of the fuse. Visual inspection showed otherwise.
So for future reference on a Phase 2 - Fuse 4 is for drivers rear sidelight - fuse 9 is for both fromt sidelights and the passenger rear sidelight.
Cheers Thumbs up
1997 Black GTi6
Posted 25th Nov 2012 at 17:27
As I thought then, a fuse...
Glad you got to the bottom of it. Thumbs up
Posted 27th Nov 2012 at 08:32
