For example if you had an oil cooler with a stat what would be the ideal open close temps for the stat?
Thanks
Ollie
| Author | Subject: oil temp/pressure |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Hi was just wondering what the min, ideal and max oil tems and pressures are.For example if you had an oil cooler with a stat what would be the ideal open close temps for the stat? Thanks Ollie |
stan_306gti6
Most stats you will buy with an oil cooler kit will open and close at 80C...![]() You will be fine with this temperature. The ideal pressure is around 4 bar when warm. Hope this helps, Stan. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
pugheaven
yes that helps thanks mate. The reason i ask is iv found a oil filter relocation kit including a cooler. Iv posted it in the general section. I cant see how you can add a stat to the kit. Thanks |
stan_306gti6
You can either get an inline stat or one which is built into a sandwich plate. ![]() Stan. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
pugheaven
but both will stop the oil to the filter and cooler not just the cooler. |
