Author Subject: Coolant Temp Issue
black 6
Lately the coolant temp gauge seems to get 'stuck' at 70 degrees even after driving for a long time. Then it will suddenly go to over 80 degrees. I suspect the temp sensor is faulty which is the blue sensor correct?
To add to the this when I first start the car the rad gets hot on the right hand side as you face the car so the stat is letting water through. I can't work this out as I changed the stat.
Please help!
Although it's no longer available new, it's worth trying to get hold of a good example second-hand. As GTi's get tubbier and cooler, it's nice to remind yourself of why insurance companies hate hot-hatches so much.-Top Gear on the 6 Apr '01. Black 6
Posted 18th Sep 2009 at 18:02
Rich E Forum Admin
Fairly easy to work out - the thermostat is leaking! There isn't any other way hot water can get to that part of the radiator.
I'd get it back apart and have a look but I imagine you'll have a broken seal on the thermostat. Sort that first and then see what the temperature gauge is doing.
Posted 18th Sep 2009 at 18:15
yep had this a few times and its always been perished rubber seal on the thermo
Posted 18th Sep 2009 at 18:20
black 6
Fitted a new genuine stat and seal and the right hand side of the rad is still getting hot. Crazy Crazy The thermostat housing cracked when I put it back together but I glued it and there is no water escaping from the housing itself. I started the car up and the water temp went up got to just over 80. Both fans came on for a bit and went off. Temp never really goes above this temp. Any ideas???
Posted 26th Sep 2009 at 16:05
black 6
Anyone?
Posted 28th Sep 2009 at 03:16
