Author Subject: Power loss when pulling away?
ritchie-t
When I went to pull away at some traffic lights not long ago the car felt almost as if it just lost power for a couple of seconds like it was being strangled. As soon as a felt it I thought I had put it in 3rd instead of 1st and I put the clutch in and went to change gear. It seemed like when I pulled the gear stick back that it was in the 1st position. I put it back in gear and all was fine. I just assumed that it had to have been in 3rd and didn
Posted 17th Sep 2009 at 22:32
mark-house
Sorry mate it could be lots of things causing it. ICV, MAP sensor, Lambda, CTS all i can say for certain it will be electrical. Get the car plugged in and have the error codes in the ECU read might throw some light on where to start.
Mine does the same occasionally and i just ignore it and put it down to it being a GTi6 Thumbs up
Peugeot 306 GTi 6
BMW 320 td compact M-sport
1967 Mini Cooper
1990 Jaguar XJR 4.0
Posted 17th Sep 2009 at 23:00
ritchie-t
Thanks for the advice Mark.
I think I will see how it goes and if it does it again, ill have it looked at. I
Posted 17th Sep 2009 at 23:08
cat/downpipe joint opening up causing a dodgy lambda reading??
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 17th Sep 2009 at 23:10
ritchie-t
Thanks for the suggestion Smile
I can
Posted 17th Sep 2009 at 23:28
dont know how to test this mate, but i know that i know mine has had this problem before, due to the engine mounts, can realy feel it bog down for a few moments.
Posted 18th Sep 2009 at 13:28
m0gsi
Sounds stupid but check tightens of battery terminals. Sometimes if they are loose the torque/push of pulling off pushes the batery back in the tray and terminals can lose contact if they are loose.
Posted 21st Sep 2009 at 18:13
spencer
Mine also does this occaionally, i just came to the same conclusion as mark...
My Xsara also use to do it come to think about it!
PH2 306 GTI 6 Big grin
Team Nile ™
Posted 21st Sep 2009 at 18:31
ritchie-t
I have just checked the battery terminals and they were fine.
I feel a bit better about it now after hearing it is not just me Smile
I appreciate all your help guys Thumbs up
Posted 22nd Sep 2009 at 03:17
