Author Subject: Annoying Knock Sound
hbinky
Not too sure what thread to post this is as I'm not sure what the fecking noise is. Basically, I've noticed very recently that when I come off the throttle there is a noticable click / tap sound in the engine bay (audible both with windows up or down). It doesn't do it when I rev the engine from standstill or when I drop the clutch whilst driving, generally it only happens when the load comes off the engine i.e. when I take my foot off the throttle on anything over 2-3k revs and this happens in all gears. At first I only noticed it when changing gear in high revs but now I notice it most of the time when I take my foot off the throttle. If I dab the throttle when driving, enough to put the engine under load, I hear it every time.
All I can think of is a possible driveshaft fault or engine / gearbox mount issue but as I've only owned the machine 3 months and am not too well versed on home mechanics I thought you guys might have a better idea before I start spending wads of cash!
Any help greatly appreciated.
Posted 16th Sep 2009 at 22:58
aaron6
Remove the top engine mount and i bet you there is a crack round the retained nut that the mount screws into. If so, just get a plate welded in and job done. Mine had the same and cost me
Posted 17th Sep 2009 at 00:52
hbinky
Nice one, I will have a look this weekend and hope its relatively straighforward to sort. I jacked the car up last night and checked driveshafts / gaiters etc. nothing untoward there so mounts was all that I had left in my tiny mind. Is this a sign that the car has had a hard life? Ive only had it three months and the bills are slowly racking up, looks like I'm going to have to work alot harder to fund the beast.
Posted 17th Sep 2009 at 14:30
hbinky
Spot on diagnosis Aaron6, thanks. Just had the garage weld a plate over the crack, as suspected. Only charged me
Posted 22nd Sep 2009 at 22:48
oecken
Also there was some "Chocks" for sale on here not too long ago, made to order from a member, they just go in either side of the top engine mount and makes it more stable / less movement so should make it last longer this time!
Posted 22nd Sep 2009 at 22:59
doon1988
Aaron, do you reckon I could have a similar thing to this? I have a knock which was subtle before but has got louder recently but it only happens when I set off from a stand still and again when Im slowing down to a standstill. Its one knock upon setting off and one knock upon stopping.
When sat in the drivers seat the sound appears to be coming from the front end somewhere.
Posted 22nd Nov 2013 at 13:22
Can you make it knock if you come on and off the throttle rapidly?
Posted 22nd Nov 2013 at 13:39
doon1988
Stan when Im setting off I tend to notice it more at lower revs/ setting off slowly. Ive been listening out and it tends to not happen when setting off with high revs.
I'll give repeatedly hitting the throttle a go later on my way home if I get the space. If I recall it doesn't knock when I do this - just jerks the car around a little but then again I wasn't testing it for this before.
I was at first thinking suspension but it doesn't happen mid drive - no matter how bumpy the road is etc. Only happens at start and stop
Posted 22nd Nov 2013 at 13:47
It sounds like it could be, however you'll know more after testing it later. Smile
Posted 22nd Nov 2013 at 13:58
doon1988
Cool I'll try that on my way home and if it happens I'll get the car round to my dads at the weekend and get looking around the engine mount as suggested above.
Posted 22nd Nov 2013 at 14:03
gilesy
4 year thread bump...nice
Posted 22nd Nov 2013 at 14:12
doon1988
Just trying to make use of the info already on here Thumbs up
but to be fair I didn't notice the original thread date...
Posted 22nd Nov 2013 at 14:17
And well done, that's what search is for. Smile
Posted 22nd Nov 2013 at 17:33
doon1988
Tried the quick dabs on the throttle and the odd time I got a knock but not everything just once or twice but was a lot of traffic so I couldn't try it much
Posted 23rd Nov 2013 at 10:55
Definitely sounds like you should take a look at the top mount then, at least to rule it out. Yes
I suspect it's probably cracked. Sad
Posted 23rd Nov 2013 at 11:38
cully
ive repaired mine today as it was a little more than cracked!
cully has attached the following image:
Posted 23rd Nov 2013 at 12:27
cully
finished job Wink
Posted 23rd Nov 2013 at 14:24
honestly3k
^Tidy job
Posted 23rd Nov 2013 at 15:10
doon1988
gahhh cheers guys will get it looked at.. Is it a big/ costly job or is it pretty simply as long as you know someone who can weld etc?
Posted 25th Nov 2013 at 08:18
cully
i did mine myself.
took me best part of the day which included waiting for the paint to dry Wink
DavyBoy on here offers a repair service for £120, I would of used him but my car is Sornd at the moment.
Posted 25th Nov 2013 at 10:38
