displaying posts 1 to 2 of 2
Author Subject: ECU
speedo306
i had a 1.6 engine and ecu i converted to a gti6 (and ecu) however when i hook up the car to the computer it is not reading the gti6 ecu. How can this be fixed?what can be the problem? do i need to put in any additional fuses or relays?
RJ
Posted 15th Sep 2009 at 08:29
ablister
to read the ecu with a fault code reader, the 16 pin diagnostic plug only connects to 3 pins in the engine ecu (the other plugs are for lives/earths, abs ecu etc). Are the pinouts different between the 1.6 ecu and 2.0 ecu for the diagnostic plug? A wiring diagram should tell you.
306 rallye, Richard Longman engine
rc10gt
Posted 16th Sep 2009 at 00:26
