Author Subject: Running Temp !!
pete-gti
Right guys , since ive ever had the car when in free flowing traffic , Water temp is reading 75 , Some times tad lower on cold days , But if in traffic etc gets up to 100 no problem , Does this sound like stuck thermo ?
Posted 10th Sep 2009 at 22:07
lotek
no thats spot on
Posted 10th Sep 2009 at 22:09
SteviePut
Should be a little warmer than 75 too I'd have thought. Saying that it's still nothing to worry about. TBH it's probably not 75 anywayLOL
Posted 10th Sep 2009 at 22:53
wilyoldave
My rallye does something similar - gauge reads 80-82 when driving but in traffic it gets to 100 quite quick the fan cuts in and it seems to come down abit but not a lot - when i drive of it goes back to 80 pretty quickley - I guess this is right?
No more peugeots Sad
Snap - no more RS clioSad
Now Ph1 RS clio Smile
Posted 11th Sep 2009 at 00:43
justinaccurate
spot on. Fans should take it down to about 90
Even with air con on it should still go no lower than 80 when warmed up, as this is the temp that a working thermostat allows water through
Posted 11th Sep 2009 at 01:06
What if the air blowing over the engine on the motorway cools it down further?
Posted 11th Sep 2009 at 01:45
wilyoldave
Fan - I only have one! more weight saving!!!
Posted 11th Sep 2009 at 01:46
SteviePut
Wouldn't make any difference as the stat would close a little to maintain ~80 degreesSmile
Posted 11th Sep 2009 at 01:50
pete-gti
So your saying 80 ? never sits at that when im moving 75 as i say , in traffic never goes to 90c once fans kick in , 95 i say !!
Posted 11th Sep 2009 at 02:12
SteviePut
The stat maintains a temperature of ~80 degrees. If your gauge reads lower then I'd say either your gauge/and or sender is wrong or your stat is slightly wrong.
Anyway, 75-80 degrees, what does it matter??LOL
Posted 11th Sep 2009 at 02:13
With the stat fully closed, can the temp go below 80 degrees if there is enough air passing over the engine, especially with both fans on half speed?
Posted 11th Sep 2009 at 03:09
Rich E Forum Admin
No chance! The heat inside the engine is far far greater than the cooling effect of a little air! Blink
Posted 11th Sep 2009 at 03:12
lwgti-6
Mine does the same.....After say 5 minutes in traffic the temp will slowly start to creep up and carry on going up. Saying that tho, my rads nackard lol!...I just bodged a manual fan switch in for the time being untill i can fit the nissens...
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 11th Sep 2009 at 03:14
