Author Subject: Intriguing clutch vibration / judder from standstill
russtav
Hello,
I wonder if anyone can suggest a solution to this...
I've had my car for 6 months and all the time I've owned it, it has had a strange clutch judder when pulling away from stand still (or from rolling speed).
The judder can be felt through the steering wheel and excites the dashboard. It only occurs when pulling away from stand still or slow rolling speed, it's no problem when changing gear (as expected I guess). It's worse on hill starts where you need to slip the clutch a bit more than on flat.
I've changed the gearbox mount, the lower mount, and put a bung in the top mount and it did not fix it. I've had someone in the car replicating the judder whilst I stand outside feeling the engine movement, and there is not a great deal of movement.
I have had driveshafts replaced and it did not fix it.
I have changed the clutch cable and it did not fix it (but made the clutch much lighter effort Smile).
It's not so much of a concern for me as it can be driven around by pulling away with slightly higher revs. And once it's moving it's not a concern at all. The clutch does not slip at all. However I might be selling the car soon, so would like to know if there is some quick fix could solve it (I'm hoping it's not a new clutch / re-face the flywheel job!).
Any comments / suggestions welcomed!
Much appreciated, Russell.
Posted 9th Sep 2009 at 23:45
acos205
You need a new clutch. Had the same problem with mine, fine when you're moving but a pain in the arse in traffic.
Posted 10th Sep 2009 at 02:15
russtav
ok cheers for the response. i thought it might be as much but was hoping for a miracle cure.
never mind, as i said it's not a big concern it's something that can be driven around quite easily.
Posted 10th Sep 2009 at 04:21
xsi_lew
noooo you dont need a new clutch, i got my clutch replaced under 5k ago and mine judders when pulling away, i think its just something that you have to live with tbh it dosent annoy me that much and if i get the right revs when engaging the clutch its fine.
Posted 10th Sep 2009 at 13:52
Either something wasn't done or done right if it still judders with a new clutch, or you have a knackered engine mounting.
if every other option has been looked at it will definitely be the clutch.
Posted 10th Sep 2009 at 15:07
russtav
yeah that sounds about right to me for a new clutch, for me i'm just not sure what any 'other' items it could be?
i expect that labour price to investigate will end up with splitting the gearbox / engine, and by that point you've spent enough money in labour to justify just buying a new clutch.
think i'll just live with it. i've kind of got used to it now anyway.
thanks for the responses.
Posted 10th Sep 2009 at 18:15
r-nab Banned!
I've heard of this before, iirc its worn clutch spings that cause the gudder ?
Posted 12th Sep 2009 at 06:19
Have you checked the top engine mount point for cracks?
Posted 12th Sep 2009 at 12:43
russtav
yep. not personally but carl chambers has reported no cracks to the mount point - he changed the cambelt during the time the judder was present.
Posted 12th Sep 2009 at 13:43
russtav
interesting. is this an easy check / fix or is it 'box off time?
Posted 12th Sep 2009 at 13:44
box off new clutch time Smile
Posted 12th Sep 2009 at 14:29
russtav
Doh
ah well, i'm not going to go to that effort on an otherwise perfectly fine clutch just to resolve a small judder.
cheers for the answers guys! Thumbs up
Posted 12th Sep 2009 at 15:26
