Author Subject: Flat Spot/Cutting Out/Running Rich?
avinash_306
Afternoon all,
I am getting a strange flat spot when getting up to 4000 rpm now & again. When it finally decides to move up the revs, its like a kick up the backside. Car starts fine from cold.
The engine does cut out 30/40 minutes into my journey. Whilst stationary in traffic - it sort of stutters and stalls? WTF
Also I think the engine is drinking more petrol than normal.
I have had the following replaced for new items recently.
*ICV/Stepper Motor
*Inlet manifold gasket
*Clutch
*Radiator
*Driveshafts
*Front & Rear discs & pads
*Full cambelt kit change/water pump
Any help would be much appreciated.
Posted 9th Sep 2009 at 22:45
gota6again
Lambda sensor?
Posted 9th Sep 2009 at 22:53
avinash_306
I should point out this is for a 99' 306 Rallye T-Reg.
Posted 9th Sep 2009 at 22:58
greenbelt
Coolant Temperature Sensor - Green sensor on the thermostat
MAP sensor on the throttle body
Lambda in the cat
^ In that order as the CTS is cheaper than the rest Wink
Standard Black 6
Black HBSC6 Smoke
Posted 9th Sep 2009 at 23:12
avinash_306
Thanks for the info. Car keeps cutting out now after 30-40 minutes of driving. Will take it to my mechanic.
Posted 11th Sep 2009 at 01:40
