Author Subject: STOP and oil light on!
chrisd306
ok my car has came on with the stop light and the oil light, it is flickering on and off an sometimes staying on, its sounding a wee bit chappy aswell topside, oil and everything ok, any ideas??
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 7th Sep 2009 at 01:03
chris with a pug
oil pump?
Posted 7th Sep 2009 at 00:56
chrisd306
is the pump in the sump on these?
& Audi Q5 S Line
chris with a pug
yeah
might be worth checking ur presure first
Posted 7th Sep 2009 at 01:17
chrisd306
what do you mean by pressure mate? oil pressure? or cylinder compression?? car was still running ok
& Audi Q5 S Line
Posted 7th Sep 2009 at 01:29
xsi-in-stealth
Is there any power loss at all?
16V-XSi
Posted 7th Sep 2009 at 01:45
chrisd306
no none at all, but saying that i wasnt revving it or driving it hard to find out, but pulled ok
& Audi Q5 S Line
Posted 7th Sep 2009 at 01:53
PeteB
The only time i get this is when the oil level is low, check it again when it is cold.
Team Nigel
selling up!!
Posted 7th Sep 2009 at 02:08
chrisd306
will check it first thing tomorrow once i get to garage plus will have 3 mechanics opinions aswell lol
& Audi Q5 S Line
Posted 7th Sep 2009 at 02:27
xsi-in-stealth
That's it you don't always notice thing unless your booting it, I've been driving my car for around 3weeks and felt fine and decided to boot it yesterday and I caked the whole 3 lanes of the dual carriage way in a huge cloud of smoke! Then the car went back to normal a few minutes later. It was a huge puff not a gradual build up of smoke, I hit about 50-60 and I heard a puff! don't know what's wrong with it just know somethings knackered!lol
16V-XSi
Posted 7th Sep 2009 at 02:54
chrisd306
well i had been booting it early on as i had done first 100mile after fitting charger, so was fine, but now light on
& Audi Q5 S Line
Posted 7th Sep 2009 at 03:10
xsi-in-stealth
Ah sorry mate didn't realise you had a charger, shows how much attention I pay to the forums!lol might be something simple, just worrying that its happened not long after the charger was fitted. Good luck with it anyway mate. Chris
16V-XSi
Posted 7th Sep 2009 at 03:24
chrisd306
right done a compression check and all cylinders are roughly the same about 200psi so anyone any ideas??
& Audi Q5 S Line
Posted 7th Sep 2009 at 23:08
webster
My stop light used to come on when I had an issue with one of the fans - this is probably no help at all but might be worth checking.
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 7th Sep 2009 at 23:34
Could be the wiring from the pressure sender unit? Oil level is ok then I take it?
Posted 7th Sep 2009 at 23:35
chrisd306
let it run for a bit, an its f*cked, its ghot a noisey rattle, would still say it is the top end rather than bottem end!
& Audi Q5 S Line
Posted 8th Sep 2009 at 00:50
gti-si
unlucky mate, no idea's as towards a cause?
1990 Cherry Red 205 Gti-6
2000 Mitsubishi Galant V6
Posted 8th Sep 2009 at 02:31
chrisd306
maybe ive dropped a valve, no sure, will whipp head of tomorrow if i have time to do it!! as my old mans garage is busy as f*ck, and im ment to be on holiday from my own work, nae chance!!
& Audi Q5 S Line
Posted 8th Sep 2009 at 02:40
gti-si
Won't be a dropped valve if you've got good compression over all four cyclinders.
Get a screwdriver on the head and see if you can locate the noise. You positive it isn't a bottom end rattle? If not I'd have the sump off
Posted 8th Sep 2009 at 03:10
chrisd306
if i take the sump off, will i be able to see easy enough if there is damage??
& Audi Q5 S Line
Posted 8th Sep 2009 at 03:12
chrisd306
had goos compression beofre the noise got worse, im thinking a valve has been close to hitting as my heads been skimmed before, and i think that it was myabe nearly hitting and now its hit!! will either have head or sump off it tomorrow or both!! depends how mad the garage is tomorrow like
& Audi Q5 S Line
Posted 8th Sep 2009 at 03:14
xsi-in-stealth
Sounds like a long day. Hope you've got a box of tricks up your sleeve or a big box of spares!
16V-XSi
Posted 8th Sep 2009 at 03:18
chrisd306
well need answers so im gonna be in early tomorrow to start!!
& Audi Q5 S Line
Posted 8th Sep 2009 at 03:20
xsi-in-stealth
Yeah that's best thing get an early start. Mine more than likely needs new valve but I want to fit a new engine if it doesn't sell, never fitted an engine but might just give it a go.
16V-XSi
Posted 8th Sep 2009 at 03:23
chrisd306
bottem end!!
& Audi Q5 S Line
Posted 8th Sep 2009 at 14:06
