Author Subject: 306 rear calipers
cwspellowe
Am I right in assuming the rear calipers on all models of Phase 2 and 3 and the Phase 1 Gti's are the same?
The bleed nipples are snapped off my rears, and air's got in the system when i was adjusting the handbrake, so i need a new caliper asap, the nipple won't drill out of this one easily.
Bye bye Sundance Kid Sad
Posted 6th Sep 2009 at 23:13
russtav
bump.
i'm also interested for this one as my car failed MOT today for offside parking brake inefficiency.
i might just buy a new caliper and be done with it rather than stripping the old one down to see what's up with it.
Posted 11th Sep 2009 at 23:24
tvrfan007
I am only aware of one caliper being used throughout the 306 range - not 100% certain though. Saxos with disc brakes and Xsaras also share the same caliper.
I've got a few spares if you're stuck. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 12th Sep 2009 at 00:40
cwspellowe
Job done, managed to save the calliper and bleed the system properly, thank god.
Cheers anyway tvrfan Thumbs up
Posted 12th Sep 2009 at 21:12
livy
how did you manage to save them?
i'm thinking of putting braided hoses all round and a fluid change.
and knowing my luck the bloody bleed screws will sheer.
Posted 12th Sep 2009 at 23:08
cwspellowe
Took a lot of fiddling about and some gypsy style bleeding from the brake pipe unions. Not recommended unless you have a qualified mechanic father in law do it for you Cool
Posted 17th Sep 2009 at 04:03
Rich E Forum Admin
How did you manage to get air in the system when adjusting the handbrake?
I'm not convinced by your bleeding method either... if you're not bleeding at the end of the line then there is always the possibility of air further down...
Oh, and for reference there are two models of these calipers; one with 30mm pistons and one with 32mm pistons.
The GTi-6 always had the 32mm ones and all phase 2 and 3 cars have the 32mm ones but phase 1 non-GTi-6 cars, the saxo, 106 and 206 (except the GTi 180) had the 30mm ones.
(206 GTi 180 has the 32mm ones.)
Posted 17th Sep 2009 at 04:32
joker
I was going to ask the very same thing! Confused
Team 375 BHP Duratec™
Posted 17th Sep 2009 at 21:55
