Author Subject: Near side ABS ring loose on driveshaft
craig_gti6
Had a look under the car this morning to try and figure out what's been causing the ABS fault...
Found that the ring on the driveshaft is actually loose.
Is it time for a new driveshaft or can this be fixed without going down that (expensive) route??
Please don't let the cambelt snap...
Posted 6th Sep 2009 at 18:12
mechanical_repairs
If you are careful you can weld a couple of spots onto the cv joint to reattach it, otherwise its a new shaft.
Carl
Posted 6th Sep 2009 at 20:30
craig_gti6
Thanks Carl,
Any idea on what a replacement driveshaft will cost? Worth getting genuine Peugeot or will a GSF one be any good?
Craig
Posted 7th Sep 2009 at 16:47
