map is in ecu box
www.paky-stunt.com
| Author | Subject: cleaning map sensor on s16 |
paky
Regular Location: Pakoštane Registered: 17 Mar 2008 Posts: 102 Status: Offline |
Is it posible to clean it on s16, map is in ecu box ________________________________________ www.paky-stunt.com |
Welly
Forum AdminLocation: Brizzle Registered: 11 Jan 2004 Posts: 21,796 Status: Offline |
Yeah a bit of fairy liquid and a microfibre________________________________________ Life is a lie. The only certainty of which is death. Go live and enjoy yourself. The clock is tickingVrs power!! |
abergavenny_306gti6
Regular Location: Abergavenny Registered: 06 May 2009 Posts: 156 Status: Offline |
i just used a foam bud find you get some oil build up in it |
paky
dan_s16
Seasoned Pro Location: Cheltenham Registered: 22 Jan 2005 Posts: 1,583 Status: Offline |
According to Peugeot it a: PAD CAPACITY 1957 46 I believe it's like a little buffer to smooth out the vacuum being sent to the Map sensor but I could be completely wrong. I've been to the local Bosch dealers to see if I can get a replacement MAP sensor and they phoned Bosch up but they weren't being very help full and said it's a dealer only part (so new ecu basically ________________________________________ When I've got time I forget what I wanted to do, and when I remember what I wanted to do, I have no time! |
paky
im asking becouse i dont have that thing on my carand when i let it in gear on idle it is not smoth it should be. Bit speed up and bit speed down iw tryed to pu new stepper motor but same thing Now i think its map sensor or its becouse i dont have that thing ________________________________________ www.paky-stunt.com |
rikky
ive heard its to smooth the flow out too, think 'swirl pot for air'i have about 5 of them in the garage from when i had map issues. eventually i replaced the ECU with another from the same year car / spec and it was fine. there is no 'sensor' as such but it picks up the reading from the outlet that is on the ecu if you pull it apart. if you have map issues i think you need to try another ecu or have it repaired ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
dan_s16
There is a map sensor but its soldered to the circuit board, I was going to desolder it then get a replacement unit from another car (i'm hoping the gti 6 one is electrically the same and solder some wires to the circuit board and then fit the map sensor out side of the ecu. whos ever idea it was to put the map sensor inside the ecu and not do a relacement wants shooting.________________________________________ When I've got time I forget what I wanted to do, and when I remember what I wanted to do, I have no time! |
doubt its the map sensor causing the idle issues, more likely to be the idle valve.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
abergavenny_306gti6
he has already replaced that though mei . . . how about engine temp sensor that could be causing it . . . |
paky
iw tryed to put new ecu from my friend and car works perfect, looks like map sensor faulty and i cant clean it becouse it is in ecu box ________________________________________ www.paky-stunt.com |
ballys16
Regular Location: Godollo Registered: 05 Mar 2009 Posts: 247 Status: Offline |
paky wrote: iw tryed to put new ecu from my friend and car works perfect, looks like map sensor faulty and i cant clean it becouse it is in ecu box Try ebay - I got one from Germany (brand new) for ~5 euros... also, you can try http://www.syntech.hu - Gabor Arvay (arvayg@syntech.hu) is someone I know who actually did mention swapping the MAP for another one. ________________________________________ XSi 8V -> S16 |
ballys16
paky wrote: As the others said - but it being there does nothing, as I did not have it when I swapped the engine and could not notice _any_ change when I put one in. ________________________________________ XSi 8V -> S16 |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
Nice pic of my engine bay there. |
