Author Subject: 18mm ball joint replacement
lars
Hi, I've just attempted to replace one of the ball joints on my 306. It previously had 16mm ball joints, but due to a mishap with the casting of the hub I've now got a new hub that requires an 18mm pin. Is it normal for the fit of these ball joints to be so tight it needs to be bashed in with a hammer? I just dont fell that comfortable hitting what I know is a brittle casting with the sort of force it seems this ball joint requires...
Posted 5th Sep 2009 at 21:56
cress87
If it's lined up properly, it should only need a tap. I just tap them in with a rubber mallet.
Posted 5th Sep 2009 at 22:34
rich-6
Remove the balljoint from the wishbone, Fit the balljoint then reattatch it all together, You shouldnt have a problem.
Like Cress says just needs a tap
Cool
RIP Pete Sims
Posted 6th Sep 2009 at 01:01
abergavenny_306gti6
put some grease on first . . . .
Posted 6th Sep 2009 at 06:56
smithers
Also helps if you push the hub in towards the engine slightly it should slip in nicely Whistle Thumbs up
1997 Black GTi6
smithers205 at hotmail.com
Posted 6th Sep 2009 at 15:07
lars
I've got the whole hub off the car and fixed in a vice. A brand new ball joint from CAS and the hole and the pin of the ball joint covered in generous amounts of copper ease. Managed to get it in, however I did have to pry the hub open by hitting an 8mm flathead screwdriver into the slot. And I mean hitting it in with a hammer, pushing it by hand was not enough. Even then I had to tap the ball joint in to get it deep enough. This french equivalency of engineering is really doing my nut in.
Posted 6th Sep 2009 at 20:18
