Author Subject: WONT START NOW
pompeygti
put juice in her this morin now she wont start. turns over but thats it, tryed towin and still nothin ?? and yes it was pettyLOL
6 number 7 is here Wink
Posted 4th Sep 2009 at 18:03
gti-si
ermmmmmmm.
1990 Cherry Red 205 Gti-6
2000 Mitsubishi Galant V6
Posted 4th Sep 2009 at 18:24
cress87
Epic win.
Posted 4th Sep 2009 at 18:27
pompeygti
Epic win.
Posted 4th Sep 2009 at 18:28
You did'nt fill her with diesel by mistake?
Posted 4th Sep 2009 at 18:36
pompeygti
na trust petty, workin fine put petty in the come out shop... went to start her and wont lol
Posted 4th Sep 2009 at 18:37
Try some easy start if you have some, if it starts for a few seconds and stops again its a fueling problem. If it wont fire at all more likely an ignition/spark issue.
pompeygti
kk ill try easy start, but dont se why it jus happened within 2 mins
Posted 4th Sep 2009 at 18:38
Check your battery connections and fuses, can you hear the fuel pump priming when you turn on the ignition?
Posted 4th Sep 2009 at 18:45
oecken
i had this on mine for a while, turned out the batter terminal connection was so loose it popped of as a drove into the petrol station, turned off, filled up went to drive away and nothing! always worth a check as it was something so simple i didnt even notice it.
Posted 4th Sep 2009 at 18:50
jcphat
Petty? I can sort out some text speak "txtspk" but baby talk.......
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 4th Sep 2009 at 19:58
xsi_lew
my car used to do that, used to confuse me like hell!
Laugh my ass off at the word petty
Posted 4th Sep 2009 at 20:09
oecken
Lol was waiting for that! is it Petty and dessy ?
Whistle
Posted 4th Sep 2009 at 20:22
pompeygti
lol... the battary is fine. turns over like a treat but nothin. i gonna go see if i can hear pump going ?
Posted 4th Sep 2009 at 22:51
t11hac
Yea put easy start in it or not!!!! IF you have just put petrol in it I would look at that first take the hose off to your fual rail then see if it is throaty if it is there is water in the petrol you will need to drain it off and get more from some where ells if that not it I would make sure you are getting a spark if not take the crank sensor out and see what nick it is in that and the cam one but do not put EASY START NEAR YOUR ENGINE MATE Big grin
has a good point the fuse is under the bonnet in the black box it is a 15amp blue one
Team Black Rallye
Posted 4th Sep 2009 at 23:08
pompeygti
ok thanks t11hac
Posted 4th Sep 2009 at 23:10
gti-si
Well first, is your fuel pump priming? If you've got a prime then you can rule out inertia switch, not that it's been mentioned, and and fuses relating to the pump.
Then you need to check the supply of fuel, but that won't be it. If you filled up with water it would still start and run for atleast 10-15 seconds while it used the fuel in the lines.
I'd guess an electrical fault. So check the inertia hasn't tripped then check your getting spark and fuel, If your getting that then you shouldn't have a problem. If not, check something hasn't popped off and make sure your earth straps and battery cable are tight as mentioned above.
Also as mentioned crank sensor.
Edit: In fact, if it didn't start at all, even for a few seconds, you can forget the inertia switch, as it would STILL run for a few seconds. It musn't have a spark. So that' either no signal from the crank position sensor or a problem with your immobiliser, or you may have blown the double relay
Posted 4th Sep 2009 at 23:58
pompeygti
this is messed up. went out to her today and she started stright up, 5 mins later wouldnt start ? hour later start sright up ? wtf is going on
Posted 6th Sep 2009 at 01:27
jimmyrallye
You prob got a bad earth on the battery mate, have you checked your fuses ? and the connectors on the battery Smile
Posted 6th Sep 2009 at 01:33
jcphat
Maybe the car is rejecting you- have you thought of a nice,reliable japanese car?
Team Zimmer™
Posted 6th Sep 2009 at 01:34
Welly Forum Admin
Dam, i hate it when this happens.
Have you tried rubbing the bonnet in a LOVINGLY FASHION i find that helps. I remember this one time right that i didn't rub her bonnet like, and i went to drive home.
Then she decided that she didn't like the non attntion i was giving her. So she fell over Sad
Vrs power!!
Posted 6th Sep 2009 at 01:38
bobdylan_55
my mrs is like this too, i just slap her ass and tell her to suck.
309 GTi6-T
Posted 6th Sep 2009 at 01:44
cress87
LOL
Posted 6th Sep 2009 at 19:59
