Author Subject: pocketed pistons
pugheaven
Hi all, iv done a search but no joy.
im looking at getting a set of 285h cams and was wondering if anyone has done or knows anyone that knows what there doing when it comes to making the cut out deeper.
does anyone know how much meat needs to be removed?
Thanks
Ollie
Posted 1st Sep 2009 at 22:59
petert
That's a bit like asking how long is a piece of string. You haven't said how lift @ TDC the 285 cam has. For example, lets say it has 0.080" lift @ TDC. Given the acceptable safe limit for an RS engine is approx. 0.055", you'd need to take a minimum of 0.025". If I was I doing it, I'd take out 0.040" minimum and deck the block to make up for the loss in compression.
Posted 2nd Sep 2009 at 16:15
crf450
We charge
Quote "da g man!"
"You've only got to watch the "306 vs ringtaxi" video & you soon realise how good these mod's are! That guy is running Ash's 30mm ARB, Solid Mounts & 23mm Torsion Bars & some adjustments on the camber. Admittedly, the guy is an awesome driver, but it just go's to show how well these cars can handle with the right modification's
Posted 3rd Sep 2009 at 18:31
how much space can you gain Martin?
also how many CC's does it add?
Posted 3rd Sep 2009 at 18:34
pedro_de_la_cruz
you can use the 285h cams without needing to pocket the pistons
if your car has had a head skim though it may be worth checking the valve clearances for piece of mind
*R.I.P Pete Sims*
