Author Subject: Head Gasket
sbk1972
Hi all
Got a 2.0 16v cab. Ive noticed that recently the car is difficult to start in the morning, it mis fires for 10 seconds, then clears its throat, so to speak.
Also, in the morning, Ive noticed that the pressure within the rad is incredible, open it up and it blasts your face off.
Ive replaced the radcap with a metal one from GSKF, so not sure if its the right type.
Car doesnt burn oil, water and there's no mayo in the oil cap, but saying all this, Ive just recently rebuilt it, and it has new oil, water, etc etc.
So, any guides on how to replace your head gasket ?? Did a search, cant seem to find much.
SBK
Posted 1st Sep 2009 at 16:20
cress87
That engine is covered in the 306 Haynes manual. Yes
Posted 1st Sep 2009 at 16:23
hbinky
If there is excessive pressure in the radiator then you could get an exhaust gas test done which will tell you if gases are leaking into the cooling system. Is it using water and overheating?
Posted 1st Sep 2009 at 16:31
sbk1972
No, doesnt over heat / or use water. However, I brought it 4 weeks ago without any front end and have slowly been building it.
I had to replace lots of the bits, rad, slam panel etc etc, so not sure if its due to the wrong radiator cap, or bleeding it wrong.
The thing which worries me is the mis fire on startup, as Ive had this with turbo supra's before and is a true indication of a HG going.
The old rad cap was plastic, the new one IVe got is metal.
The car doesnt over heat, fans come on around 90, and for the short periods IVe run it, doesnt white smoke, or mayo in oil.
How easy is the HG on this ?? By the looks of it, the exhaust manifold looks a pig to get too.
Simon
Posted 1st Sep 2009 at 16:34
cress87
Nope, your engine will have a little cast exhaust manifold (unless it's been swapped for an J4RS manifold). It is apparently a massive pain in the arse on a GTi-6 with the 4 branch manifold. Yes
Posted 1st Sep 2009 at 16:43
sbk1972
Oh right, so the exhaust manifold on my car wont be be as difficult then ??
What annoys me, is that last week the car was stripped down, inlet off, cambelt off, so should of done it then !!!!
I cant find an guides / steps to do a HG though. Torque settings ,etc etc
SBK
Posted 1st Sep 2009 at 17:07
cress87
Should all be in the 306 Haynes manual. It doesn't cover the GTi-6 engine but it does cover yours. Yes
Posted 1st Sep 2009 at 17:15
sbk1972
I havent got a haynes manual, and was hoping I might find a guide here.
SBK
Posted 1st Sep 2009 at 17:20
smegal
306 haynes manual
Use this to open it.
Ex SC-6
Now in a Megane R26
Posted 1st Sep 2009 at 17:28
sbk1972
Thanks for the manaul. Have downloaded it :-)
SBK
Posted 2nd Sep 2009 at 01:49
