Author Subject: HELP ASAP!!! new engine wont start
eddy_gti6
i fitted my new engine yesterday got all the harness pluged in and put all the fluids in today.
just went to start it but it wont start, it all turns over fine but doesnt seem to want to start. any ideas? Huh?
Posted 31st Aug 2009 at 22:39
daviewonder
I know this sounds obvious but have you checked the fuel cut off switch?
Why is it that shoe repairers are so good at cutting keys? - Harry Hill.
Posted 31st Aug 2009 at 22:40
fletch
Track Head
Inertia switch, crank sensor connection, fuel pump, multifunction relay behind ecu...
Posted 31st Aug 2009 at 22:41
eddy_gti6
no mate, didnt think of that, al go give it a press now Big grin
Posted 31st Aug 2009 at 22:42
eddy_gti6
Inertia switch??? whats that?
Posted 31st Aug 2009 at 22:45
daviewonder
I think its the posh name for what I said Big grin
Posted 31st Aug 2009 at 22:47
willygti
the button above the battery box, its either red or black.
Team Ducati 748
2003 Subaru Impreza STi
Posted 31st Aug 2009 at 22:51
eddy_gti6
red lol. tried it, didnt work, checked fuses, there ok, fuel pump doesnt sound like its working but just checked and there is fuel coming through
Posted 31st Aug 2009 at 23:24
eddy_gti6
do i have to get my ecu unlocked if i am running a new engine? just i am using my old wiring look, ecu and box
Posted 31st Aug 2009 at 23:26
ECU should be fine if you are using the same ECU, transponder and key. Yes
When you turn the ignition on to the second click, can you hear the fuel pump prime? If not, check the red and black relay which is attached to the back of the ECU box. Yes
It is held on with a single 8mm nut, make sure you rememebered to plug this in. Yes
Also check crank and cam sensors are plugged in. Yes
Stan.
Posted 31st Aug 2009 at 23:33
eddy_gti6
i cant here the fuel pump prime, i will go and check the plug beging the ecu now.
i will be back to let yous no if i ahve any luck LOL
Posted 31st Aug 2009 at 23:41
eddy_gti6
right lads i am 100% sure its my fuel pump not working. any idea what i can do to fix this?
Posted 1st Sep 2009 at 00:03
birk
Use a make shit gravity fed fuel pump, big bottle with fuel in it higher than the fuel rail with a pipe going into the fuel pipe feed, then a pipe from the return feed line into a bottle lower than the fuel rail, then you will know if it works or not.
Or you could just get a new fuel pump LOL
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 1st Sep 2009 at 03:43
eddy_gti6
that sounds like a bit of a f*ck on LOL i am goin to check a few plugs tomorrow and if i cant get it started its going to the garage LOL easy way for me Big grin
Posted 1st Sep 2009 at 04:14
you got 12v at the inertia switch?
Posted 1st Sep 2009 at 04:20
eddy_gti6
i am geting 12v on my volt gauge meter if that helps?
Posted 1st Sep 2009 at 04:32
nope!!
you need to see if the ecu is sending the signal to the relay to power up the fuel pump.
without unlocking you wont get a prime, without crank you wont get any more.
with a buggered relay you'll get sod all.
Posted 1st Sep 2009 at 04:37
rich-6
I was always under the impression that the ECU will lock itself if its unplugged from the car without the ignition turned on and will have to be sent off and unlocked for it to work again, Even if its for the same car it was removed Unsure
Or is that only transferring between cars?
You've said you are getting fuel, So the pump must be fine as must the Relay? Mine Couldnt be heard priming everytime you turned the key, It would only do it if it was left for a while.
Cool
RIP Pete Sims
Posted 1st Sep 2009 at 05:09
eddy_gti6
so is that the red fuel cut of switch under the bonnet and is that what needs unlocking?
Posted 1st Sep 2009 at 04:42
eddy_gti6
i have had no engine in my car since about the 15th august and just got my engine in yesterday and wired up. tried starting it but there is no sound from the fuel pump, i can usualy here my fuel pump when i go to start my car but since the new engine is in there is nothing. i will give it a good going over in the morning
eddy_gti6
i am not getting any fuel or a spark from the plugs. any ideas???
Posted 1st Sep 2009 at 16:32
jcphat
It sounds as if the immobiliser is playing up the fuel and sparks will not work if the key and ecu are not from the same car or if the connectors are dud so double check that each of the connectors is clean and fully engaged also check the engine earthing.
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 1st Sep 2009 at 16:38
cress87
As lots of others have suggested, check the relay box on the back of the battery box. If you unplug it and short out two of the pins on the loom plug then you should hear the fuel pump run.
Short pins 5 and 8 on the loom plug. If the pump works then the relay is fubarred.
FAQ
Posted 1st Sep 2009 at 16:40
eddy_gti6
key and ecu are from the same car, i tried bridging 5 & 8 on that plug and there is nothing
Posted 1st Sep 2009 at 17:19
hman205
Try resetting the ECU
Another Broken one
Posted 1st Sep 2009 at 19:02
