Author Subject: Heater problems...
china_daz
Hey guys.. after some help if possible please?
As you may know i have just got another GTI-6 and when i bought it i knew the heaters were not working..however i have no idea where to start to try and fix it?
Basically, nothing works at all..none of the knobs do anything whatsoever??
Anybody had this problem at all?
Help would be greatly appreciated, Thanks
Phase 2.5 T Reg Diablo 6 - Lowered 60mm - French Plates - Fully Colour Coded - Push Button Start - Full Stainless With Decat More to come..
Phase 2 S Reg Nile 6 - Lowered 40mm - In 6 Heaven
Phase 2 R Reg Black 6 - Sold!
Posted 30th Aug 2009 at 15:12
keven b
Check the relays under the steering wheel to the right, pull them out and check they havent corroded, mine stopped working and 1 of them was the problem, cant remember which 1 though, sorry
Posted 30th Aug 2009 at 21:21
johng
Hello,
I'm having the same problems.
I intermittently loose all power to the air con and ventilation control panel.
I'll take a look at the relays.
JohnG
Posted 31st Aug 2009 at 23:08
china_daz
ok thanks for the advice i will take a look tomorrow Smile how do i know if a relay has gone though?
Posted 1st Sep 2009 at 02:42
miles
It's not normally the relay but the contact's getting hot which is the issue, Easy to see by melting plastic
www.pugracing.com
Posted 1st Sep 2009 at 04:19
darktyke
i cant get mine to stop working.
relays? Confused
Posted 3rd Sep 2009 at 02:56
china_daz
well.......... i checked the relays, all seemed fine, then checked the fuses and found the 30amp was blown so i quickly replaced that thinking that was my problem,
Very quickly after turning on white smoke started coming out from every part of the dash and the fuse i just put in was glowing red hot Sad. i disconnected the battery and this stopped the smoke,
What do i do now as i have no idea what is wrong at all?
Posted 3rd Sep 2009 at 20:33
johng
Hello
My problem with intermittently loosing all power to the air con and ventilation control panel has returned. I never know if I will have heat or not, which is not good in this weather.
Can anyone advise please?
JohnG
Posted 4th Dec 2010 at 04:29
johng
Hello, found the fault heater relay.
Far left of the 4 relays at the top of the fuse box, but the relay in my car was brown, not green.
JohnG
Posted 6th Dec 2010 at 01:46
jonnie205
sounds like a seized motor
Posted 6th Dec 2010 at 02:18
eddy_gti6
check the fan, its under the passenger side of the dash. mine has stopped working as well and some how snapped as well Huh? bought a new one off someone on here over a week ago and still not got it yet due to the snow. i hope!!! nightmare as the inside of the windscreen keeps freezing up
Posted 6th Dec 2010 at 02:23
johng
I have a working heater fan again after swapping the relay.
It looked like the relay had burnt out.
JohnG
Posted 6th Dec 2010 at 02:31
craigy_87
hmm relay seems fine on mine
the fuse keeps blowing though, the fans ran for a couple of seconds then the fuse blew again
Posted 8th Dec 2010 at 17:44
johng
My heater fan is working fine now, got the correct green relay installed.
JohnG
Posted 9th Dec 2010 at 03:28
shredder11
Are the heating systems easy to replace, i.e. the fans or if there is a main unit etc? I suppose I need to have a shufty through the Haynes manual for detailed info, on what the whole heating system consists of.
How much do the replacement relays cost and are they readily available, or only from scrapyards?
Posted 24th Dec 2010 at 03:35
finally had a look at mine [phase3] and it's hte green relay next to the grey one which had pin 5 melted and all seized to the plastic relay holder. prized it apart, got rid of a bit of the plastic where it melts to the other surface and put another relay in. job jobbed
Posted 26th Dec 2010 at 19:43
will130787
I have a thread in general about this if it helps anyone...
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 27th Dec 2010 at 02:31
